Currently running my Shiva MK IV Tapped-TQWT in "prototype" mode i.e. sans bracing, stuffing and terminus cover (which technically means I'm running in TQWT mode, rather than Tapped-TQWT mode), and the seal provided by placing the subwoofer on the carpet. I get down to 25 Hz at least but output is obviously compromised by incomplete sealing. (below 30 Hz, the sub appears ready to levitate on account of sound pressure.
Question: I understand it's been recommended to stuff the first half or so Tapped-TQWT to remove some undesirable upper harmonics To this end: Can I get away by merely lining the walls, as opposed to stuffing them. I'm concerned that stuffing this enclosure will limit the "tapped action" i.e. the path from the terminus to the throat and back?
"Any fool can know. The point is to understand" - Albert Einstein |
#2 |
Maximum damping occurs at the closed end, so with a traditional TL/TQWT where you're willing to accept some HF ripple/deep notch at its 3rd harmonic to get ~max gain LF BW, you just line it about halfway down and adjust it by adding more only at the closed end. Doesn't hurt to line the folds either: DSL DTS-10: AVS Forum
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
Thanks, I'll stuff the line over the next few days ( currently involved with bracing and the such)
#4 | |
#5 |
Just an update. The final result works, and works well. Not as efficient as a full out horn sub when used with a pair efficient speakers (above 95 db/w/m), but gets deep enough below 30 Hz and way more efficient for anything less efficient i.e .the typical 87 - 90 db/w/m design.
Subjectively, I prefer the pyle driver (tighter bass) but the shiva can get louder and handle more power I'll post measurements when I can
#6 | |
| Line Length of a ML-TQWT | chairforce | Full Range | 2 | 14th July 2010 07:38 PM |
| Tapped Horn or Transmission Line | mrevie | Subwoofers | 4 | 17th May 2009 07:38 PM |
| How should I fill/stuff/line my small sealed fullrange sphere? | GuyPanico | Full Range | 3 | 9th August 2007 01:15 PM |
| Transmission line stuffing question | Mike2 | Multi-Way | 1 | 23rd February 2005 12:25 AM |
| Transmission line or TQWT with 2 woofers in 2 way system ? | promitheus | Multi-Way | 27 | 16th September 2002 04:04 PM |
| Page generated in 0.07879 seconds (83.56% PHP - 16.44% MySQL) with 11 queries |
