Qts Qes Qms?
Qts Qes Qms?
Old 5th August 2010, 07:25 PM   #11
GM is offline GM  United States
GM's Avatar
Because the weaker the driver, the weaker the cab's air mass 'spring' must be for a given Fb.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th August 2010, 07:46 PM   #12
scampo77 is offline scampo77  Canada
Send a message via Yahoo to scampo77
so what constitutes a "weak driver" loose/stiff suspension? heavy motor? power rating?
i am working with square kicker L7s and they need to be in a huge box and i am trying to unsderstand why
Old 5th August 2010, 08:22 PM   #13
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Qts Qes Qms?
A motor that is not very powerful is probably the simplest description.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 5th August 2010, 09:42 PM   #14
GM's Avatar
Yeah, if Trevor's and Cal's answers didn't make it plain enough I can't think of a simpler, yet educational, way to explain it ATM.
GM
Old 5th August 2010, 10:00 PM   #15
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by Cal Weldon View Post
Qts: the higher the number = the drivers inability to come to rest after the electrical signal has ceased. a rating of 0.707 is just right for a lot of folks. If you like drier bass, around 0.5 - 0.6 is better. if you like speakers from the 70's, a little higher 0.8 - 1.0 will make your ears happy.
Do you mean a QTC of .707 or QTS...
Old 6th August 2010, 01:24 AM   #16
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Qts Qes Qms?
I guess I mean Qtc of 0.707
planet10 needs your help:
Let's help Ruth and Dave
Old 27th March 2013, 12:04 AM   #17
RickDangerous is offline RickDangerous  Mexico
Thanks to all for their input on this. I am in Mexico and it's hard to find books a) in English b) about these things. Plus ordinary folk on forums sometimes explain things in a way that easier to understand than books...
Scampo77, have you come across any great links/books about all this?
I am especially interested in having an idea of :
- what is a better? Higher or lower ?
- what is a good figure ?
(for basically all the Thiele Small parameters, such as for example here :
Celestion TF0510 5" Professional Speaker 30W 294-2050)
Many thanks guys!
Rick
Old 27th March 2013, 03:10 AM   #18
OscarS is offline OscarS  United States
actually you have the right idea with regards with electrical damping analogy of under/critically/over damped; they purposely describe the "ringing" in this physical system. Since an electrodynamic loudspeaker is simply a force driven, damped spring-mass harmonic oscillator, the electrical analogue is very well known and can be found in any college level Physics 101, Electromagnetics, Differential Equations, etc college/university level textbooks.
The same terminology describes the Frequency Response magnitude vs Frequency of a speaker. Lower Qts= more overall damping (not necessarily over-damped because it is all relative), higher Qts= less overall damping. Too high Qts (not enough damping) can result in a peak in the magnitude response within the pass band; too low Qts can result in a very high F(-3) high-pass roll-off, which can hinder bass response. Again, this is all relative as there are an infinite number of loudspeaker alignments to consider.
Qms and Qes are simply the two constituents of the total Quality Factor (Qts). They [Qms and Qes] work together in the "product over sum" rule to establish the total Q(ts).
Engineering is the Best: January 2008
Thiel_small_analysis
Old 8th November 2013, 12:16 PM   #19
Philosophil is offline Philosophil  Canada
Philosophil's Avatar
Originally Posted by Trevor White View Post
The Qms is a measure of the damping caused by the mechanical damping of the diaphragm suspension. A higher Qms means less mechanical damping.
The Qes is a measure of the electromechanical damping caused by voice coil resistance and the interaction of the voice coil in the magnetic gap. A higher Qes means less electromechanical damping or a smaller magnet.
The Qts is the total damping which is the combination of mechanical and electromechanical damping.
Qms is always much larger than Qes because the electromechanical damping always dominates.
I've been on a steep learning curve and am trying to get a better grasp on these and other notions. I think I have a reasonable enough understanding of Qms and Qes (at least for my lay purposes), but I'm still puzzled about something.
If Qts is the sum of Qms and Qes, then why is it that when I look at speaker stats, the Qts is a lower number than both Qms and Qes? There must be something simple that I'm missing here.
Old 8th November 2013, 12:25 PM   #20
Did it Himself
Qts Qes Qms?
It's not the sum. It's product over sum.
Qts Qes Qms?Hide this!Advertise here!
Does Qms, Qes, and Qts explain a driver? Hybrid fourdoor Multi-Way 29 27th March 2013 01:02 AM
what sounds best . . . Low Qts in small cab or higher Qts in bigger cab mikelm Subwoofers 18 15th July 2009 10:46 AM
QES, QTS, QMS values for Hiquipon Ow1 lovitz Multi-Way 1 20th January 2006 10:50 AM
Tuning Qes Qts Bl Mms P Zolt Multi-Way 10 21st April 2005 05:24 PM
What if instead of a speaker with a Qts=1 I use a different Qts?? Tuliman Multi-Way 2 14th December 2004 11:54 AM
