New Budget Home Subwoofer Project - Page 2 - diyAudio
Old 2nd August 2010, 02:45 AM   #11
Sulla is offline Sulla  United States
Thanks for the info GM. And I have another question. Since it is a sealed enclosure with smoother drop off than a ported sub it should have a little more useful low end below 36Hz when you factor in boundary gain and room gain correct?
I will see soon how it sounds with this enclosure. I got it about 90% done today. Just need to cut the hole for the subwoofer and wrap the botton third where it is indented. Look like a mid century moderm cube type design. Something like a Bose 501 but hopefully better haha. Anyway when the subwoofer comes in I will let you know how it sounds.
Any way hopefully this will perform really well for most music and good for home theater. As a side note I watch a lot more old movies than I do new ones.
Old 2nd August 2010, 03:35 PM   #12
GM is online now GM  United States
GM's Avatar
You're welcome!
In theory, but being located at LP normally means not near any boundary or where room gain is high other than the floor (2pi space) and at the current size it will have to be heavily stuffed to lower Qtc enough to maybe extend the audible BW a bit lower enough to take at least a little advantage of any room gain, though it will improve SQ if you're one of those relatively few folks that are sensitive to LF damping.
Auditioning it damped with one side, back and top or bottom wall covered with 1" acoustic fiberglass insulation or similar and then with it heavily stuffed will 'tell the tale' the range of performance tuning options and whether or not it will please.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 2nd August 2010, 03:47 PM   #13
Well because of the room the LP is right next to the back wall so maybe that will help?
Also I was going to ask how close does it need to be to the floor to to get a boost from that boundary?
Old 2nd August 2010, 03:59 PM   #14
Just thought of another question. Since the sides are all braced against each with a little bit of ribbling with each does it even need damping at first? Or would it be better to listen to it and add damping if it has ringing etc?
Old 4th August 2010, 03:35 AM   #15
GM's Avatar
Yes the extra boundary will increase acoustic efficiency up to +3 dB and even more if near a hard corner.
For best coupling/mirror imaging we want the driver as close as practical, but the WLs are so long in the LF that it's not real critical.
The damping is mostly for quelling eigenmodes somewhat and keep them from reflecting back through the driver which can give the box a hollow sound, but try it without to see if it's acceptable to you. Still, all things considered, heavily damping it to get a lower tuning to take max advantage of that room loading seems the solution, but only one way to know for sure........
GM
Old 4th August 2010, 04:21 AM   #16
OK that is what I was thinking. The box is now setup with the woofer next to the floor and really is more stable this way anyway.
For damping my plan is now to try it without any damping or stuffing when the woofer gets here. Then after a few days take it apart and try it with the full dampening. Then make a choice from there.
Old 6th August 2010, 03:34 AM   #17
Finally got the subwoofer in and got everything together. It sounds good. Much less sloppy than my Cerwin Vega home theater sub I was using. Also really fills in the bass when pared with my Polk SDA 1 main speakers.
Next thing to do is make a cover to hide the subwoofer.
Attached is a very low quality image but it gives you an idea.
Old 6th August 2010, 11:24 PM   #18
Got the stuffing added today. And it did help.
Old 7th August 2010, 04:14 AM   #19
GM's Avatar
Good! Yeah, my 'loud is beautiful........' sig line was CV's mantra decades ago, but they lost their way........
I love a happy ending.
GM
Old 7th August 2010, 04:17 AM   #20
Happy endings are always good haha. Ya I always like CV to. Just wished they made better speakers now days.
Home Theater Project w/ DIY In-wall 8945P speakers and IB subwoofer wigginjs Multi-Way 1 21st January 2010 08:21 PM
Custom Home Theater Project in New Home, Opinions appreciated. thadman Multi-Way 5 20th November 2008 01:40 AM
Budget Subwoofer wasted911 Subwoofers 9 9th June 2008 12:39 PM
Ratshack Budget Subwoofer bickeler Subwoofers 16 3rd April 2008 04:57 PM
A budget home-theater solution. Berethorn Digital Source 19 14th August 2004 12:27 AM
Copyright 1999-2017 diyAudio
