Should I protect the electronics of my plate amplifier from my speaker?
I am building a sealed enclosure for the Dayton 15" RSS390HF-4 reference subwoofer. The enclosure is 24" x 24" x 20" deep. I had intended to purchase the Dayton SA240 or the Bash 300w plate amplifier but neither is available until mid-September or later and I can’t wait that long to finish the project. So instead I bought an MCM 50-6263 200w amp. When I received the MCM I discovered it has no housing. The electronics are exposed, and this made me wonder. If I cut a rectangular hole in the back of my cabinet and install this amp in the normal fashion, these exposed electronic parts will sit about 10" from the large magnet that is part of the speaker’s driver assembly. My questions are: If I install the amp inside the cabinet in the standard fashion, will the speaker driver slowly magnetize or otherwise harm the electronics of the amp over time? Will the backward pounding of base notes physically harm the amplifier? Should I instead place the amp in its own box on the back of the cabinet? Place a grounded metal plate between the amp electronics and the speaker? Use some other method to shield the amp? Or am I worrying about nothing? Any advice will be appreciated. |
#2 |
That's WHY it is called a plate amp. It is an amp built on a plate.
Yes.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 |
OK, glad to hear it. Unless I hear otherwise, I'm cutting a hole and inserting the electronics of the plate amp inside the enclosure. Thanks.
#4 |
If it's a ported cab, it'll also help cooling a little, by introducing an air flow. That will depend on the position of the ports though.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#5 |
As noted in the original post, its a sealed enclosure, not ported. But the important point is that you agree that I can stick the amp's exposed parts inside the box without fear. And so I will. Thanks for the response.
| PCM1732U shielding & Grounding | KevinLee | Digital Source | 4 | 1st February 2008 11:21 AM |
| Shielding air core inductors (T-Amp) | xyrion | Class D | 6 | 20th October 2007 05:58 AM |
| DIY Plate Amp --> Need the Plate!!! | gmikol | Parts | 4 | 17th February 2006 08:20 PM |
| Impedance Matching & Crossover network query | Redhatter | Multi-Way | 0 | 6th January 2004 07:59 AM |
| amp project query | jlg4104 | Tubes / Valves | 3 | 29th August 2003 05:34 PM |
| Page generated in 0.08264 seconds (73.52% PHP - 26.48% MySQL) with 10 queries |
