Dear valuable diy users,
I have this set of speakers removed from my car. I want to use them in my home. Please give me a hint about how to build some apropriate chases for them. Thank you, Eugen JBL T595 Limited Difuzoare auto JBL Coaxiale , T595Limited , T 595 Limited
eugen |
#2 |
Car speakers are designed for use in a car so they probably will not be very good for the home...
#3 |
hm.... does anyone else holds buggers's position?
Should i still try to make those boom boxes? Thank you,
eugen |
#4 |
Small sealed angeled boxes that you put against a wall with the speaker facing forward on a slanting baffle.
Or anything else that comes into your mind. There is probably no right way to do it without first testing so... If you have some spare time and scrap wood to try it out then why not. I would not expect miracles in terms of sound quality but it might be a fun and learning project. *edit* Did you want to use them as a sub or keep them fullrange? |
#5 |
...perhaps someone should at least ask what size the speakers are?
car speakers are normally designed to run open baffle, so you'd need a larger box... you could also try a box that larger than normal, and tune it to maybe 50Hz... |
#6 |
Simply put car speakers do not suit sealed boxes unless they are very big, and the EQ needed for speaker boxes is not built into car speakers. Keep them in the car, and buy or build some proper hi-fi speakers : Zaph|Audio - 4" Bargain Mini or Zaph|Audio - ZMV5 - MCM / Vifa 5" System /sreten.
#7 |
Someone asked for the specs
3 way coaxial 15 x 24 cm (6"x9") power: 150W RMS (300W max) Freq response: 35Hz - 22kHz Sens (SPL): 94dB impedance: 4 ohmi titanium tweeters installation depth: 118mm cutting dimensions: 152x229mm Actually i have two pcs of JBL Studio L890 floor standing speakers for hify listening and a Harman HK 990 amp. Indeed for the L890 the frequency starts from 27Hz as for the car speakers it starts from 35Hz. You all may be right about the quality of the sound.
eugen |
#8 | |
eugen |
#9 | |
The specs are meaningless, utterly meaningless in terms of hifi speakers. /sreten.![]() Somewhat overengineered in terms of the number of tweeters IMO. Your car 3 ways could work in stuffed sealed boxes as wall/corner rears. |
| acoustic foam and Box volume | mcmahon48 | Multi-Way | 2 | 6th March 2009 12:46 AM |
| box acoustic compliance experiment with Iron Lawbreakers | thoriated | Multi-Way | 7 | 15th August 2008 04:14 PM |
| Suggestions for minimizing acoustic resonances in large sealed box ? | Paul W | Multi-Way | 8 | 8th February 2008 04:04 PM |
| acoustic foam vs. box volume?? help | dste6 | Multi-Way | 2 | 27th September 2006 06:31 PM |
| A question about building a sealed box (acoustic suspension). | piro | Multi-Way | 3 | 8th March 2005 08:51 PM |
| Page generated in 0.10239 seconds (81.49% PHP - 18.51% MySQL) with 10 queries |
