Old 29th July 2010, 02:45 PM   #1
Default 6th order bandpass design for pro audio use
Hi Everyone:
Looking for examples of successful 6th order bandpass systems (commercial or DIY) for commercial use.
TIA,
Old 29th July 2010, 04:02 PM   #2
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
There are 3 proven designs for bandpass enclosures on the Speakerplans Website
Speakerplans.com
The plans state that they can be licenced for commercial use
Old 29th July 2010, 05:36 PM   #3
Speakerplans.com
Thanks! I've been running through numerous possible TH alignments for a 12" driver I recently purchased, and it looks like I might get results more to my liking (size vs. performance) if I go with a "simple" 6th order BP alignment instead . I'm looking for some layout ideas to accomodate the alignment I've come up with - those links should come in handy.
Old 30th July 2010, 04:59 AM   #4
Kind of a tight fit, but theoretically 0,-3dB from 50 Hz to 150 Hz, 98dB SPL, and a box under 4 cu.ft.... tempting! I might build both this and the larger TH to see which one sounds better...
Old 23rd August 2010, 01:06 AM   #5
tinitus is offline tinitus  Europe
Hey, anyone tried to do "upper" port slotted a bit like this ?
My goal is bass guitar, and may just be 4.order
Old 23rd August 2010, 01:35 AM   #6
You can't play bass with just a bandpass sub.
Talking two boxen here and a crossover. N'less
yer higher tuned port hole, or slot is centrally
located and phased to double as the indirect
radiator for midbass.
Karlson K15 is the enclosure you want...
Trace Elliot BX-80 was also slotted indirect
radiator similar to drawing post above...
Old 23rd August 2010, 02:25 AM   #7
ofcourse not
while you posted I drew another one, implementing the front driver
personally I think its a daft idea
anyway, the idea was to use a smaller woofer, and still get SPL, and control
and front driver not playing low bass could be chosen for much better upper range, and thus have strong motor with very low Qts
Im not sure it needs much xo, if any at all ?
Hey, maybe a 12" coax as front driver
Theres a new Beyma with 2" tweeter
Seems like a tough driver with good xmax, and low Qts
http://www.beyma.de/fileadmin/seiten...l/12XA30Nd.pdf
That way this design might be used for just about anything
Old 24th August 2010, 01:19 PM   #8
freddi is offline freddi  United States
freddi's Avatar
not sure if thsi was commercial, and don't like to view Karlson as "bandpass", but for two drivers one could try Humphrey's isobaric Karlson-coupler (with no reference to Karlson) - it could be a vented variant - not sure what to do with "wasted" space - maybe just a central leg for support - a regular Karlson would be good in mid and high quality
Speaker system which inverts and ... - Google Patent Search
Old 24th August 2010, 04:27 PM   #9
clever guys, those old pioneers of audio
anyway, next devellopment
Eminence Delta pro-12A, and Kappa pro-12A
Delta in top "waveguide", and Kappa in bottom 6.order bandpass
Delta in small closed box rolls off around 105hz(-3db)
Kappa, around 40-100hz bandpass
It will do 115db with 120 watt
Could look like "over-ingeneering"
but woofers are "affordable"
Its just more work
WinISD pro to simulate 6th order bandpass subwoofer christophorus Subwoofers 14 13th September 2006 12:58 PM
6th order bandpass design - TheWacoKid Subwoofers 5 2nd August 2006 03:02 PM
A question about 6th order bandpass design simon5 Subwoofers 5 5th December 2004 09:29 PM
6th-order Bandpass BAM Subwoofers 1 24th September 2001 05:51 PM
6th order bandpass design? SubNut Subwoofers 3 22nd September 2001 08:48 PM
Page generated in 0.11461 seconds (72.46% PHP - 27.54% MySQL) with 11 queries
