Single sheet TH challenge
Old 16th April 2011, 09:42 PM   #951
FlipC is offline FlipC  United States
Chaps - funny how the English guys really haven't picked up on the TH's yet.
Sold off my FLH's because the TH's sound so much better. Glad to hear you like them as much as I do.
Djim - not sure about Chaps but I haven't had to EQ mine.
Run LP at 151 Hz with a 24 db LR and a 24 db LR HP at 33 Hz. But at same time I have not had time to do real test to see where I would even need to. Might get some time to do that next week.
Old 16th April 2011, 09:48 PM   #952
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
I think it's because they tend to use huge stacks of FLH's that have enough mouth area in aggregate to get low without going TH.
How many folks in the US start out with 8 or more bins?
Dan
Old 16th April 2011, 10:59 PM   #953
Djim is offline Djim  Netherlands
Thanks Flip, could you let me know when you fire your babies if you have the feeling your LF is dropping?
Old 17th April 2011, 01:56 AM   #954
Chaps is offline Chaps  Denmark
Originally Posted by Djim View Post
Chaps, how much EQ do you use and what kind of low-cut filter are you using?
No EQ on subs at all. LR48dB HP filter .. Didn't think the subs really needed any adjustments at first, but the plan is to find a place where i can do some prober testing and maybe do some adjustments on them - if needed
Old 17th April 2011, 03:47 AM   #955
Indeed that's the perfect setting for Linkwitz-Riley 48dB/Oct, pity you don't have access to Butterworth. If you are going to check try this setting: 40Hz / Q= 4 / Gain= +5dB
Old 17th April 2011, 01:38 PM   #956
jbell is offline jbell  United States
djim:
I know they don't measure flat to 40, but they sure do sound good.
I have only used a 2-3db bump at 45hz before when running 40hz LR 48db/oct.
I did get around to trying the 32hz BUT 24db high pass that was suggested a few pages back. Yea it seems to keep excursion in check as predicted and did add a couple db in the 40hz department, enough that I eliminated the eq bump when running this way.
From ear anyway both sound similar... But then 28hz&32hz d&b isn't my thing.
Old 17th April 2011, 06:41 PM   #957
Originally Posted by jbell View Post
djim: I know they don't measure flat to 40, but they sure do sound good. I have only used a 2-3db bump at 45hz before when running 40hz LR 48db/oct. I did get around to trying the 32hz BUT 24db high pass that was suggested a few pages back. Yea it seems to keep excursion in check as predicted and did add a couple db in the 40hz department, enough that I eliminated the eq bump when running this way. From ear anyway both sound similar... But then 28hz&32hz d&b isn't my thing.
There are more possibilities you could try although it's true that not everybody needs it: High-Pass (low-cut) = 12dB/Oct at 47Hz (Butterworth)
Para EQ = 38Hz / Q = 2 / Gain = +4,4dB (make up for the filter)
Para EQ = 40Hz / Q = 6 / Gain = +6,0dB (make up for the system)
Jbell, your SS15 sounds good no question about it but I guess everybody has is own reason for judging what is necessary for LF or not. It's just I don't agree with a statement that d&B is the only music genre that benefits form LF extension. Pop and rock these days also use the same technologies that makes LF possible in recordings. Besides pop and rock, dance oriented music is fully accepted over here in Europe and D&B is just a small genre within. A good example are the big (rock?)festivals that program dance oriented acts for the last 10 years or so. 30 years ago almost no one cared or understood LF figures, freq plots, extended excursion or kilowatts. Today all leading brands offer that extra LF extension simply because there is music for it and a market that demands it because they understand the technology behind it a little better. That's how I see it.
Old 17th April 2011, 09:41 PM   #958
CRESCENDO is offline CRESCENDO  United States
Since the 3015LF had a crazy price increase, thought I'd share this:
A lot more power, but a lot more 40Hz
(This example uses an inductor (@ Le) with isn't necessarily needed)
File Type: jpg SPL SS15 (4) 15N850v2 vs (4) 3015LF soho54's corner.jpg (79.6 KB, 516 views)
Old 17th April 2011, 10:09 PM   #959
Same BMS 15N850v2 driver, 5 more liters than the SS15 (226 vs 231) - nice little shift to the left.
Old 18th April 2011, 01:09 AM   #960
Originally Posted by CRESCENDO View Post
Since the 3015LF had a crazy price increase, thought I'd share this: A lot more power, but a lot more 40Hz. (This example uses an inductor (@ Le) with isn't necessarily needed)
Cresendo, would you be so kind to share the price of an 1200 watt rms inductor that doesn't saturate at these levels? Secondly, would you be so kind when you leave out the inductor to show us group delay and transient plots? And if you found those plots you might realise that you can build 9x SS15's + the extra wood with 18Sound 15W700 drivers that do not have any delay, transient or response issues in the SS15
Single sheet TH challengeHide this!Advertise here!
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
