Old 8th April 2011, 05:33 AM   #921
Default Dangerous thinking - double the trouble or double the pleasure?
So, I've got drivers, got the wood (not cut yet) and I'm thinking -
Why not build a (mirrored) double SS15?
After all, most of us will always use them in pairs!
They will still be much lighter than the average bear...
These tapped horns seem to work particularly well on their longest side, bottom to bottom.
If you share bottoms, do you actually need a divider between the two SS15 halves?
(Or just bracing?)
Most dual boxes tend to be smaller than a pair of singles, would this also make a worthwhile difference here?
Regards, Ben
Old 8th April 2011, 09:12 AM   #922
(Or just bracing?)
Regards, Ben
The plot thickens!!!!!!
Sam
Old 8th April 2011, 11:13 AM   #923
Yep -- I've built 150lb subs before....
For the record the pyro subs weigh in at 112Lbs.
Old 8th April 2011, 11:57 AM   #924
Default Weight is not always the issue
but I agree, double 112 and you get heavy.
Old 8th April 2011, 01:05 PM   #925
jbell is offline jbell  United States
mine is 50...
looking forward to your upright and side 28v@10m and upright and side pair of cabinets 20v@10m measurements.
Old 8th April 2011, 01:16 PM   #926
So am I, coz I've got a stack of 3015LFs waiting for a home....
Old 8th April 2011, 03:09 PM   #927
My 2c -- follow flip's lead. Original ss15 design, add handles...
Old 8th April 2011, 04:16 PM   #928
Ben,
A box double the size of a SS15 could take advantage of a longer path length and the additional enclosed volume, thus lowering the cutoff frequency. It would require different folds, it would be a different design entirely.
Simply doubling the SS15 width won't result in a lower cutoff frequency, it will just make for a box twice the size and weight, less the weight of one, or even two side panels.
Nothing wrong with that, but it would then be a big box, loosing one advantage most see in the SS15 design.
Old 9th April 2011, 03:26 PM   #929
It's looking that way.
Old 10th April 2011, 04:26 PM   #930
Chaps is offline Chaps  Denmark
Had the camera out today while finishing up my first 2 SS15 (other 2 only needs paint to be finished). My first build :-)
First 2 boxes done and testet .. Only thing missing is the connectror plate on the back, but it's on it's way (just needs powdercoating)
Nice little stack. In the future i will be building my own tops also, but for now, this actually works out very well.
Me trying to be "camera-creative" .. The grills really gives the finishing touch!
Almost forgot .. Build pic!
They will be powered by a 4-channel MC2. Delivering 750W into each cab (love headroom!). Had a quick try today, but my nabours didn't fancy loud music and especially not for a long time, so didn't get the chance to crank them up to max volume. BUT i was impressed by what i heard. Very clean and tight bass. Really looking forward to next weekend where they will be doing their first job!
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
