#891 | |
#892 | |
Other than a (possible) difference in meters, was there any difference in the way you tested your cabinet than the way Jim tested his? What "better" way do you have to test it? By the way, it is no easier to dial in 28.3 volts than it is to dial in 2.83 volts, they are just 20 dB different in level, one watt or 100 watts into an 8 ohm nominal load. It is easier to set the level if you turn down the amp gain in either case. Get the voltage correct at 60 Hz, don't mess with it at different frequencies, chances are your meter will be most accurate at 60 Hz, and may be "off" at other frequencies. Set the level without a load to get it close, then trim it out with the load (speaker). Some amps won't change in output voltage at all between no load and loaded, others do change, especially with lower impedance loads. At 28.3 volts, you will be able to see the speaker move a bit, but it will still have more than six dB of headroom left down to 45 Hz or so. If your cabinet has a longer path length than the SS15, it may have a slightly lower Fb, or Fc. Speaker excursion in standard horns just increases as frequency decreases. Fc (horn cutoff) is the normal term used for the LF corner with horns, but TH actually behave more like BR than regular horns at the low corner, there is a pronounced excursion minima, followed by a very rapid increase in excursion. A lower Fb with the same box volume reduces LF efficiency. A lower Fb in a smaller box volume (space taken up by corner ramps, etc.) reduces LF efficiency further. As long as the speaker does not run out of excursion, you can use EQ to make up for the lesser output down to, and slightly below Fb. With EQ, you may be able to squeak a few Hz more bottom extension (at a lower maximum SPL level) out of your box than a "standard" SS15. Art |
#893 | |
If you don't have a wind screen for your meter, you will often have to wait a long time between gusts. Even with a wind screen, using the Magnitude Response with Smaart, I spend far more time waiting than measuring, but at least I can look at the Coherency trace to see if the measurement has suffered from wind contamination. If the wind is steady, (never is here in Madrid, NM ) with a dB meter, it is hard to tell how much LF is wind noise, and how much the speaker is putting out.
#894 |
Pyros, you need a detailed drawing from your ‘custom’ SS15 otherwise all this good help is for nothing. That way you can translate your cab back to a corresponding HornResp prediction and find the points in your design that can benefit from a little re-arranging. Also from a corresponding HornResp you can calculate exactly the max power you can use and as long your amplifier doesn’t go over that max you can eq as much as you like at any point in the bandpass!
#895 |
#896 |
And we Europeans already make a lot of fuzz about those 'tiny mini' ghetto blasters on our beaches ;-)
#897 | |
#898 | |
Nevertheless, it still doesn't matter how much and where you EQ as long you don't feed your cab with more watts then its max safe power (from predictions or real life measurements). |
#899 |
That's probably the case for every alignment simulated by a program that doesn't take BL nonlinearity into consideration. Most assume that the driver behaves at large signal levels the same way it does at small signal levels, which is simply not true.
#900 |
Dave NonZero -
Well the cabients have a -7 to -10 DB drop at rear to rear off axis. Plus some cancellation. And being 15' off rear wall I wasn't getting any real reflections. IE none of that boom room node going on. BUT if you notice there is also have a pair of 12x1" 2 way's as monitors. So cutting through wasn't a problem. My ears weren't ringing at all afterward. Though I only went out in front maybe 3 times the whole night. And only in front of the speakers for the last song. To get a quick massage! Salz - no those arent DIY tops. JFL210's. |
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
