#861 |
I actually prefer using a much smaller high-power resistor (e.g. 4 ohms) and using the method I suggested. It's a longer approach, but it also allows me to generate much higher voltages across the speaker and therefore track how t/s params might shift under higher drive levels.
#862 |
#863 |
Yes you are right Brian, for accurate measurements your should change the 10 Ohm resistor in at least half the Re of the loudspeaker. You also need to measure the resistance of the cables.
#864 |
"I'm with djk, but a 1000 Ohm resistor is large enough."
No, it's not. Some low Qes drivers can have impedance peaks in excess of 200Ω. A 1000Ω resistor in series with that kind of driver is hardly constant current, and will result in inaccurate parameters. I generally use a Crest amplifier that will drive 92V RMS.
Candidates for the Darwin Award should not read this author. Last edited by djk; 4th April 2011 at 05:09 AM. |
#865 |
Post #864
Hi djk, It's probably mostly irrelevant to the discussion of the SS15, but 1000 Ohm is quite a normal value for this measurement. I have never heared of anybody that applies 92Vac to the constant current circuit for measuring loudspeaker impedance, but that just proves, that I have to get out more. :-) Regards.
Oliver |
#866 |
I realize that that is the value that most people use, and I explained why it is an incorrect choice.
BTW, my HP 200 generator (tubes) can put out 40V into 600Ω.
Candidates for the Darwin Award should not read this author. |
#867 |
back to ss15 projects
![]() ![]() here i just started today, didn't order the 3015 yet, will do that this week. going to dinner now will continue construction later on tonight! good ol made in USA ply ![]() got everything cut, started tracing out on the side piece. i also added some angled cuts to the pieces that don't meet at 90 deg to make it go together a little better. ![]() should i add corner reflectors in every corner? i don't mind the small amount of extra added weight if they'll help and i have the wood sitting here.... |
#868 | |
Give it a search, just my 2 pence. Al |
#869 | |
#870 |
Here are the unofficial results. I wish it was better down lower but I got a good peak at 180Hz. I am calling it good to make more. Any other thoughts? Andy
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
