Old 3rd April 2011, 02:35 PM   #851
Originally Posted by 4pyros View Post
Can I cheak the resonance of the TH sub by cheaking the AC current with a DVM and looking for a Dip? Andy
Suggestion: Get a WT3 and use it to measure the impedance response of the TH. It will tell you all you need to know, including the resonance points, AND if there are any sections that need more bracing.
Old 3rd April 2011, 06:30 PM   #852
Ya I dont think I want to go that far to test one speaker, maybe I would measure the voltage across a resistor if I had to. Andy
Old 3rd April 2011, 06:36 PM   #853
Believe me, once you starting building speakers, a WT3 is probably one of the best, if not THE best tool you can have in your toolkit.
You can take the long way around and hook a resistor in series with the speaker, and then use voltage measurements across that to calculate impedance at varying frequencies. A WT3 will do the same for you in seconds. It's worth the $$.
Old 3rd April 2011, 08:26 PM   #854
I believe you, But I am only making one speaker.
Cant I do the same thing by measuring the AC current with a DVM?
Andy
Old 3rd April 2011, 08:31 PM   #855
Andy
Sure, if your DVM has an internal impedance of zero and it can measure current accurately for frequencies from 0 to 200 Hz or so .
Old 4th April 2011, 12:27 AM   #856
djk is offline djk
djk's Avatar
The woofer tester has an AC constant current source that drives the speaker and an AC voltmeter to measure the resulting voltage drop and then calculates the impedance from this data.
Candidates for the Darwin Award should not read this author.
Old 4th April 2011, 02:14 AM   #857
Djim is offline Djim  Netherlands
Old 4th April 2011, 03:15 AM   #858
djk is offline djk
djk's Avatar
No, put a 10KΩ in series with the driver and measure the voltage across the driver with a true RMS AC voltmeter.
Old 4th April 2011, 03:25 AM   #859
tb46 is offline tb46  United States
Hi 4pyros,
I'm with djk, but a 1000 Ohm resistor is large enough. Then you can use the precision 10 Ohm resistor in place of the speaker for an initial calibration. If any of this is unclear, get a WT3 :-).
Oliver
Old 4th April 2011, 03:46 AM   #860
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
