Single sheet TH challenge - Page 78 - diyAudio
Old 28th March 2011, 05:25 PM   #771
FlipC is offline FlipC  United States
I get mine from PartsExpress.
It comes power coated and isnt much more than what I can purchase locally that isnt.
Mine took so long because of the engraved letters and handles.
Salz - no these are not standard SS15's.
The 12 took 13 sheets. All I have left over is a small pile of strips of various sizes. I retained the overall size and also the baffle angle. Changed the interior.
4pyros - where you located?
maybe one day we can get a HUGE linkup of SS15's ... (:
Old 28th March 2011, 06:25 PM   #772
New entry ... it's over at 3015lf TH @ 35-40hz but only 20" deep help
Much more bass but much less power.
Don
Old 28th March 2011, 06:59 PM   #773
That sounds like a challenge, LOL.
What's the FR look like?
Old 28th March 2011, 07:18 PM   #774
All the stuff is on the other thread ... but:
SS15 in gray, NewGuy in black. Giving up 5dB for 10 Hz may not be your cup of tea, but someone might like it.
Don
Old 28th March 2011, 07:25 PM   #775
Hmm... 5dB is quite a bit (but then there's that 10 Hz!).
How does a simple vented box of the same volume with the same driver compare?
Old 28th March 2011, 07:44 PM   #776
The NewGuy is much lower, but no louder than Jerry McNutt's one driver vented box, but we know that vented boxes don't make their maxes without
chuffing. OTOH, the NewGuy sure looks ugly above bandpass.
Don
Old 28th March 2011, 07:57 PM   #777
A mod similar to what I proposed for the THAM15 might extend the passband up a bit, but then again, who wants to use a subwoofer box above 200Hz? :-)
I wonder if anyone's done any testing to determine if there's any turbulence effects at lower frequencies with the mouth facing the driver rather than down the passageway. One of the reasons why I chose my more complicated fold for my TP was to avoid the possibility of that happening, however small.
Old 28th March 2011, 09:01 PM   #778
weltersys's Avatar
What do you mean by "much more bass but much less power" ?.
Does it exceed Xmax prior to full power?
That would be OK for the pontoon boat, but PA guys would probably tear up the cone if that is the case.
Old 28th March 2011, 09:23 PM   #779
Djim is offline Djim  Netherlands
And the so called 'new' version of the 3015lf that is sold over the last year even has a higher excursion in designs based on the old 3015lf...
Old 28th March 2011, 10:14 PM   #780
This box moves the F3 down by 15 Hz (35 Hz compared to 50 Hz) but with much less power. It reaches xmax at 280 - 290 Watts.
Jim's SS15 is a much better deal unless you just gotta have 35 Hz.
Don
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
Copyright 1999-2017 diyAudio
