Single sheet TH challenge - Page 54 - diyAudio
Old 8th March 2011, 04:54 PM   #531
Here are the new path dimensions for the box drawing in post #521.
S1=462.90cm2, S2=512.37cm2, S3=793.55cm2, S4=1901.20cm2, and S5=2413.70cm2
L12=17.15cm, L23=128.9cm, L34=83.50cm, and L45=22.225cm
Old 8th March 2011, 04:58 PM   #532
The over all path leght is about 97.875" long, but do you do the box resonance from S1 to S5 or S2 to S4 in a tapped horn.
Is this question to simple or to hard to have no replys yet?
Andy
Old 8th March 2011, 06:44 PM   #533
tb46 is offline tb46  United States
Hi 4pyros,
If you are thinking about a resonance frequency as in a bass reflex enclosure, the tapped horn doesn't work that way. Take a look at the impedance curve in Hornresp, it may help. Otherwise, maybe these threads by Don Snyder will be of use:
Elements of a Tapped Horn
Evolution of the Tapped Horn
Oliver
Old 8th March 2011, 07:41 PM   #534
Djim is offline Djim  Netherlands
Hey 4Pyros,
I don’t know how accurate your drawing is but it looks like your corner corrections (corner bracing) can be improved.
Old 8th March 2011, 07:46 PM   #535
Thanks Oliver I will look at that. Ya the mouth area thru me off to. Andy
Old 8th March 2011, 08:04 PM   #536
OK Djim; A peeny for your thoughts. The braces in the corners were put there to stiffen the box, eliminate parallel sides and take up some of the volume in the big corners. The top one may not even be needed now that I added the extra angled board in the middle. They were not dimensioned because thay will be made from what ever is left over after the rest of the box is cut. I dont think the dimensions are critical as long as the angel is graiter than 11 degrees.I also plane on doing some central bracing from the back, across the lower part of the speaker mount piece, to the bottom. Its just not on the drawing. What are your thoughts? Andy
Old 8th March 2011, 09:31 PM   #537
Andy, a couple of months ago there were some discussions about bending in TH’s (Jbells "flute theory") Since then I have read a lot about bending in 'big' flutes/horns. Besides that I also have been talking to instrument makers and engineers that are involved with butane gas installation (high pressure) who also work a lot with bending.
Anyways, it’s not the parallel walls (resonance) you should worry about but it’s about so called ‘non-gentle-bending”. This is often represented in 90 degree bends in TH’s. Instead of resonances it’s the difference in speeds of the air molecules (high mass - low mass as result of those speed differences) that can cause errors in the output. For instance if you have two 180 degree bends in a ‘S’ form construction, they both will equalise the speed as result of the ‘S’ form (opposite bending construction). You can call such construction a gentle bending.
But many TH designs have often two 90 degree bends that are not the opposite of each other. They bend in the same direction and therefore amplify the speed differences. In that case your bends can benefit from corner corrections to optimise the pathway.
Instead of one corner brace I use at least two braces per corner to get a more ideal pathway. In realy big corners I use at least 3 bracings to come closer to the ideal path. I'll use your drawing as an example...
Old 8th March 2011, 11:31 PM   #538
In regards to grills, I read jbell's intention of using the Dayton square grill: http://www.parts-express.com/pe/psho...62-898&scqty=1
You get 1 pair - each grill is just 2 inches shy of getting 2 SS15 grills from 1 Dayton grill for $55. You've got quite a bit left over... Looks like a bit of wasted grill..
Has anyone had success with other gill material/brand?
Justin
Old 8th March 2011, 11:32 PM   #539
Djim; So you are saying the additional deflectors would keep the air molecules moving faster around the outside of the bends? I read that 45 degree deflectors are no good, your thoughts? Should I do the corners of the other 180 degree bend as well? Would it be worth it to use one half of a 10" pipe in that bend?
Thanks Andy
Old 8th March 2011, 11:41 PM   #540
Justin; I am using expanded and flattened aluminum with 1 X 3/8 slots mainly to keep the mice out. Picked up 2 4'X8' sheets from a local aluminum supplyer for $75 total. Its listed in McMasterCarr for a lot more.
Andy
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
Copyright 1999-2017 diyAudio
