Single sheet TH challenge
Old 19th August 2013, 03:37 PM   #1971
flight120 is offline flight120  United States
Thanks Trackzilla! Lookin' forward to it.
Old 8th October 2013, 03:34 PM   #1972
johnnyrocks209 is offline johnnyrocks209
Anyone have any new pics of the HS12 or SS15 they can share or experience with them in a live sound setting.
Thanks, John
Old 8th October 2013, 09:59 PM   #1973
kmixx is offline kmixx
built 6 of the ss18's so far.....these things rock. I still cant get over the fact that you can really steer the bass with these.
Old 9th October 2013, 06:44 PM   #1974
Kmixx, can you post some pictures of those? I haven't seen one built yet.
John
Old 10th October 2013, 10:49 AM   #1975
freddi is offline freddi  United States
freddi's Avatar
i'd like also to see the ss18 pictures (and plan)
Old 11th October 2013, 12:35 AM   #1976
fhperez is offline fhperez  United States
Send a message via AIM to fhperez Send a message via MSN to fhperez Send a message via Yahoo to fhperez Single sheet TH challenge
I want some SS18's as well..
The best DJ in Houston using the SS15 born in diyAudio from Jbell and the rest of the community!!
Old 14th October 2013, 01:33 AM   #1977
bitSmasher is offline bitSmasher  Australia
bitSmasher's Avatar
Originally Posted by jbell View Post
The simplified version of the ss18 is tall and skinny, vs a more typical sub aspect ratio....(the 3012lf in the simplified ss18 cabinet will give 125db flat to 40hz at 50v input, no massive eq required)
intradesting... I retired my SS15 (with 12") as they were too "boxy", but a taller form factor appeals...
Old 15th October 2013, 03:27 PM   #1978
DrDyna is offline DrDyna  United States
DrDyna's Avatar
I'm also interested in any pictures / plans for these, if anyone has any.
Old 21st October 2013, 07:39 AM   #1979
m R g S r is offline m R g S r  United States
I thought I read that jbell didn't release the plans for the ss18.
It's on,y two pages back. He said he hasn't had time to post up yet, and he's been busy
Trackzilla said he has the sketchup file if you guys want it.
Old 11th November 2013, 04:46 AM   #1980
Brian Steele is offline Brian Steele  Grenada
Oliver:
I have issues translating what I draw to hornresp as well, it only makes sense that others have the same issue....
However the goal in this case was a dual taper TH with the main taper change at the upper back. My cell phone took a lousy pic the other day, so here is my layout with some additional dimensions called out.
Just resurrecting this....
I've been trying to put together a spreadsheet to assist in designing THs with this type of fold. I don't know if anyone's picked it up before, but it looks like "S3" should actually be at the bottom of the vertical panel that's in the middle of the enclosure, rather than up in the top right corner...
"S2" and "S4" are basically at the driver, so that seems to leave only two locations for "S3", if you want to get a good HornResp model:
(1) at bottom right hand corner, if the internal panel attached at this point is parallel to the first panel after "S1" or
(2) at the bottom of the vertical panel in the middle of the enclosure, if the internal panel attached to the driver's baffle is not attached parallel to the first panel after "S1".
Here is an example of the spreadsheet, with S3 set as option 1 given above. The spreadsheet is not quite finished yet, but it's good enough to use to "tweak" the panel dimensions via computer before committing a design to wood.
www.diysubwoofers.org
Single sheet TH challengeHide this!Advertise here!
Here is a Challenge latala Solid State 41 12th May 2011 02:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 09:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 04:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 05:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 09:41 PM
