Single sheet TH challenge
Old 20th July 2013, 12:37 PM   #1961
mfavata is offline mfavata  United States
Thanks for the reply, 4pyros! This community is great. I just did a google search for the pyro musicals, as I had never heard of them. They look pretty awesome. Too bad they only did the 4th this year. Sadly I'm at work right now so I won't make it down to King of Prussia, but hopefully I can catch your setup at another upcoming event.
Old 24th July 2013, 01:19 PM   #1962
johnnyrocks209 is offline johnnyrocks209
Hi all,
I will be building 8 of these this summer and just hope someone hear can tell me if 3/4 plywood will be ok for the build. I want to use higher power subs so I want to use stronger wood...any help would be great.
John
Old 24th July 2013, 01:25 PM   #1963
Hi Crescendo,
I live in Stockton and looking for some advice on some builds I have coming. ANy help would be great.
Thanks John
Old 24th July 2013, 07:07 PM   #1964
overflow is offline overflow
Default Maiden Voyage
I took this picture last year on the maiden voyage of my SS15 build. The subs are almost stock build with 4015 drivers and 50% compression plates. The tops are the HS12 with the Dpro12 and (2) D220Ti drivers on a homemade waveguide - not great, but decent. Biamped tops. We were restricted to 90db at 100ft, but you could hear them crystal clear a mile away. Right side stack was the same. Throw and clarity was amazing.
Jon
Old 24th July 2013, 08:26 PM   #1965
Jon
Hi overflow. What was your reason for doubling the number of ports and using two compressions drivers in each midtop?
Old 25th July 2013, 12:23 AM   #1966
The cabinets are deeper to accommodate the dpro, so four holes are needed to get the tuning. The double compression was to simplify the waveguide. As such, each horn only flares 7.5" vertically. 15" is a little too much.
Old 25th July 2013, 06:50 PM   #1967
Overflow,
Awesome looking build and it's very similar to what I will be building this summer. What are you using it for and describe the sound. I will be using for live sound mostly. Thanks for posting the pics and if you have any more of the tops close up that would be great.
John
Old 15th August 2013, 04:08 AM   #1968
flight120 is offline flight120  United States
Hey Trackzilla,
I sent a PM, but would you mind sending me the plans for the SS18?
Thanks!
Tommy
Old 15th August 2013, 09:42 PM   #1969
grecon is offline grecon  United States
Hey Trackzilla,
I'd like a copy of the ss18 plans too!
thanks, Greg
Old 19th August 2013, 07:38 AM   #1970
Trackzilla is offline Trackzilla  United States
Anyone wanting those plans needs to message me their email address. I will send you the same sketchup file I received. It's pretty darned straightforward from there...
Keep in mind, I may take a couple of days to notice & respond to requests, it's still pretty stupid busy 'round these parts.
Single sheet TH challengeHide this!Advertise here!
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
