Single sheet TH challenge - Page 193 - diyAudio
Old 22nd March 2013, 01:10 AM   #1921
PASC is offline PASC  Brazil
Hi!
Playing a bit with cone correction on SS15:
First without, than a circle ring in front of the cones at two boxes, a longitudinal cone correction at two boxes and now will compare with circle piramid in the horn in front of the cones.
http://img2.uploadhouse.com/fileuplo...57c87b87e4.jpg
http://img9.uploadhouse.com/fileuplo...15003d7d29.jpg
http://img4.uploadhouse.com/fileuplo...47dce11e71.jpg
PASC
Old 22nd March 2013, 03:33 AM   #1922
bitSmasher's Avatar
Ahh, over a month since my last post here, too many distractions
Braces should be going in mine tonight/tomorrow, a cleanup of glue + edges is in need then a quick coat of paint.
Definitely need braces:
Harlem Shake - bS Trolley v2 - YouTube
Old 22nd March 2013, 01:56 PM   #1923
BP1Fanatic's Avatar
What car amp are using?
Old 3rd April 2013, 09:46 PM   #1924
I have a strange problem with my build. The ss15 is made a bit wider and loaded with B&C NDL76. Hornresp didnt show any problem with the modification so i went for it. When the volumes hits a certain level it sounds like the cone/spider/something-speaker-related starts to rattle. The noise gets louder as the level gets higher. I gentle tried to place my finger on the cone at the level the rattle begins and the rattle got loader.
Any ideas what the problem could be?
Old 3rd April 2013, 10:21 PM   #1925
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
Hi JW
Are you running a high pass filter on your SS15's to stop the speaker from exceeding Xmech? The driver rapidly unloads below 35Hz.
Old 4th April 2013, 05:43 AM   #1926
Cone/spider may be getting warped. I have got repaired several EV 15" and 18" drivers which had torn cones/spiders, due to non-optimised loading coupled with high drive levels.
Sam
Old 4th April 2013, 07:48 AM   #1927
I'm new to this whole DIY world but knows how to handle a saw, so the problem seems very strange for me. I havnt applied a HP filter due to the fact I didn't knew it was
this important . It sounds like it could be the fix to my problem. I'm going to buy a 50hz one and I'll then get back to you when it's fixed (crossing fingers)
Old 4th April 2013, 08:41 AM   #1928
Xoc1's Avatar
50 hz is too high.
Read this first
Old 4th April 2013, 11:28 AM   #1929
re post1928,
Did you mean to point us to post1901?
It has no information on high pass filtering.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th April 2013, 01:10 PM   #1930
Xoc1's Avatar
The link directs to Single Sheet Challenge Post 733
Here is a Challenge latala Solid State 41 12th May 2011 02:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 09:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 04:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 05:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 09:41 PM
Copyright 1999-2017 diyAudio
