Single sheet TH challenge
Old 8th January 2013, 05:33 AM   #1911
bitSmasher is offline bitSmasher  Australia
bitSmasher's Avatar
Still yet to make sawdust, but constantly thinking about the build in anticipation of getting started in 2 week's time...
Speculation, what would be gained/lost by going wider?
Approximately 630mm / 25" external - 605mm / 24" internal
Why? If i'm building two or more at a time, then starting with ripping a sheet in half lengthways and cutting to size from there would make more sense. It'd still work out to be 1 sheet per cab, but a bigger box and more usable offcuts with every strip the same width.
Has anyone considered this, and does the idea make sense?
Old 8th January 2013, 12:45 PM   #1912
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
The ingenious bit of the SS15 layout is the fact that by making the cab narrower the there is enough material to make the path longer.
Jbells initial cutlist is in Post 39 Single sheet TH challenge
There is not a lot of spare timber in a SS15. If you rip all the timber to half width to increase the width of the cab, how you are going to get it all out of one sheet?
The 24" dimension is used for the front to back dim of the cabinet this maximises the cutting yield for the sides and top bottom panels.
Old 9th January 2013, 06:27 AM   #1913
bitSmasher's Avatar
I think I misled myself whilst struggling with Cutlist's clunky interface... forgot to include a couple of panels... oops!
Regardless the intention won't be to get a single sub out of a single sheet but builD multiple boxes at once. I realise that strays from the SS challenge but I'm still sold on the design for its performance potential (especially specific to my application) than the fact it's frugal on wood.
So yeah, 24" strips for the build, with a bit of additional bracing and other bits and pieces to come from an extra sheet which (if it's all at 24" wide) can be used for more boxes. Oh and it reduces chance of disaster if a few cuts are bodged!
Keeping it all 24" wide will make things much easier for a n00b builder, so the question still stands - how will the extra width affect performance?
Old 9th January 2013, 02:59 PM   #1914
weltersys is offline weltersys  United States
weltersys's Avatar
The original dimensions are 22" x 24" x 30".
Going to 25" wide won't make any appreciable sonic difference, it will just waste wood.
If you want a better sounding cabinet, easier to build, use 3/4" since you don't seem to mind wasting wood .
Art
Old 25th January 2013, 03:15 PM   #1915
maxo is offline maxo  United States
Originally Posted by djk View Post
A dozen 3015LF are $104 each from martinsoundpro.com, the 4015 about $139, the Peavey is more$ from what I can see.
so they raised the prices now uh ?
they are 239 as of now
Old 25th January 2013, 07:36 PM   #1916
djk is offline djk
R.I.P
djk's Avatar
The 4015 has gone up $5, POA on the 3015LF (volatile pricing from NEO) .
The prices I quote are for those "in the trade (dealers)".
The 11 oz NEO slug went from about $3 five years ago to over $60, it has declined a bit from the peak. Too rich for my blood.
Candidates for the Darwin Award should not read this author.
Old 6th February 2013, 01:28 PM   #1917
bitSmasher's Avatar
sawdust!
after a few (maybe 8-10) hours in the workshop, I am pretty close to assembling a pair of SS15 with EPA's mod to suit my Delta 12LFA drivers...
Here's one cut up, sitting on the trolley which it'll eventually be strapped to for portable battery-powered sound:
MDF is a hassle to work with, but since this is just an experiment I'll be happy to rebuild with ply if/when necessary.
Just need to cut the driver hole, and hopefully it'll go together easily!
More pics and details to come later, it's 1:30am and I have to get this together for a street party in 2 day's time.
Old 18th February 2013, 03:37 AM   #1918
bitSmasher's Avatar
Didn't get it built for Reclaim The Lanes, but probably better than I can spend some time to get it right... this is what I've ended up with so far:
Rushed build, slightly bodgy but it's a trial so far... have played with them a bit (much to my housemate's annoyance) and they make some noise!
When the mouth braces are fitted I'll take them outside to measure and evaluate... for now, the novelty of being loud and shaking the place is good enough for me.
Old 18th February 2013, 04:42 AM   #1919
epa is offline epa  Netherlands
cheers
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 18th February 2013, 04:49 AM   #1920
bitSmasher's Avatar
Thanks again epa! Definitely owe you a few beers.
This was put together a bit bodgy, with some very visible errors in measuring/marking, but I'm still hoping it'll perform just as well as the sims suggest...
Single sheet TH challengeHide this!Advertise here!
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
