#1851 |
ic
so on the list of recommended driver there are only 3 kappa 3015lf 4015lf I would like if is not to much to ask to add the other divers people have used on the SS15 USA and Europe what is the weight of an SS15 empty |
#1852 |
@ maxo,
Just because somebody somewhere built an SS15 with XYZ woofer is not a reason for Jbell to put a stamp of approval on it. Jbell has made recommendations based on HIS testing and expirence, if you choose to stray from them just remember YMMV.
Regards, Dan |
#1853 |
Thanks Neo
#1854 |
Been following your posts and I know your excited to make a move on something. SS15's generally are an excellent choice for a live band, but low synth stuff and dubstep is going to be a problem for them. Realistically a high pass filter that removes that sort of content is a requirement.
Regards, Dan |
#1855 |
Basically the weight of the sheet of wood you use to build it, not a lot of scrap in this project. Where in the country are you?
Regards, Dan |
#1856 |
Thanks Neo
can you make it with 1/2 inch plywood ? i am in Laredo, TX found on post 794 you can use 18sound 15w700 http://www.eighteensound.com/index.a...simple&pid=208 i dont know if that sells on the usa and post 796 3 more drivers with graphs from Djim 18Sound 15ND830 (neo), P.Audio C15-600EL and the 'old' RCF l15P200AK (4ohm version). Last edited by maxo; 6th December 2012 at 12:12 AM. |
#1857 | |
#1858 |
Epa ,
The Tham fold looks good, but so does the SS15 style fold, a scaled up Brian Steele POC#2 type fold design might also work .... Forsman also came up with a Tham style with an extra fold that looks pretty crafty My designs so far have a straight taper, so of course any of these folding styles would have to be adjusted to get a straight taper (instead of a rapid expansion at the end of the line) and also the compression, line length and taper ratio would all have to worked into the fold design to get the output to match my sims as close as possible ... A scaled up POC#2 is the closest in most regards, the fact that his design is "stepped" may not hurt one bit and would actually simplify the construction a little... I have updated my SS-18PS76 inputs, it now has a slightly longer path length but its still only 209 liters, and seems to require less inductance to get flat, in fact i think this one could be run with no series inductance added to the 18PS76 driver, which means less expense and decreased losses .... The bump at 50 would likely be knocked down and flattened by the DFD mod.... By the way, for uber power handling an 18sound 18LW2400 also looks awesome in this cabinet with a little added inductance, the 18TBX100 and 18TBW100 also look decent enough with additional series inductance added ... The dimensions seen in the comment field are rough dimensions for a super simple single fold cabinet... |
#1859 |
#1860 |
hi matthew
i did a little folding myself,but no luck so far(apart from single fold) the le value rizez as freq drops,for subs you can easely double le value.
one good thing about music ,when it hit you feel no pain. so hit me with music.
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
