Single sheet TH challenge - Page 185 - diyAudio
Old 3rd December 2012, 12:51 AM   #1841
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
What is DFD, is there a thread somewhere?
Dan
Old 3rd December 2012, 01:07 AM   #1842
Matthew Morgan J's Avatar
Its one of Brian Steele's fantastic creations ! Maybe he will jump on here and explain ...
Here is a link to his proof of concept # 2
The Subwoofer DIY Page v1.1 - Projects : "Proof of Concept #2"
Old 3rd December 2012, 04:16 AM   #1843
Mr Steele's POC#2 cabinet was built for a 12" driver and he made his DFD work with it ... I'm only suggesting that the DFD may also work with what is essentially a scaled up version of his cabinet ..
Old 3rd December 2012, 04:32 AM   #1844
epa is offline epa  Netherlands
dfd dog food duct if im not mistaken
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 3rd December 2012, 06:23 AM   #1845
Right!
Its a very carefully placed restriction in the line ... Extremely sensitive to it's position in the horn path ...
here is more about it , check out the explanation in post #171
THAM15 - a compact 15" tapped horn
Old 3rd December 2012, 04:46 PM   #1846
maxo is offline maxo  United States
Jbell,
will you add this mods on your 1st page of this thread
for the "slim" version of your SS15
along with the budget drivers listed there like
Dayton PA310
B&C 12CL64 12" Neodymium Woofer 294-694
2Ω JBL 265F-1
Eminence Delta-12LFA 12" Low Frequency Driver 290-416
not in order and not sure if all of those can fit an SS15 with 16" or 14" wide
Well if 24x30x14 is your ideal -- build that.
As it happens -- a ss15 is 24x30, and if you build it 14" wide and put a Dayton Audio ST305-8 12" Series II Woofer in it... you can get 120db at 100watts with just about the exact same response profile (just lower total output) as the full size ss15 version.
You are good up through 200 watts so you've got plenty of headroom available on that driver. Highpass at 30hz.
(wonder if that config should be added to the singlesheet thread as a SS15slim)
Posted on this post #10 of this thread
~50 lb tapped horn, woofer under $100, high efficiency, low power?
Old 3rd December 2012, 05:20 PM   #1847
i think an extended tham maybe suit your sim.
. hr driver db
Old 3rd December 2012, 05:25 PM   #1848
Jbell
wrote this
and on the thread above they speak about those drivers i posted
they dont say any about the tham
Old 3rd December 2012, 06:49 PM   #1849
sry maxo
the reply was meant for matthew.
. hr driver db
Old 3rd December 2012, 08:15 PM   #1850
jbell is offline jbell  United States
Originally Posted by maxo View Post
Jbell,
Dayton PA310
2Ω JBL 265F-1
This was just a bit of hornresp "arm chair quarterbacking" aka, it's not something I've built and tested. Yes it should work just fine, but I'll reserve post1 for the tried and true, things I've built and tested. I don't want anyone to confuse anyone.
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
Copyright 1999-2017 diyAudio
