#1811 |
So I spent the past week at work reading through this thread in my (ample) spare time at work... woah there's a lot to take in, some great discussions along the way!
I've convinced myself that building a bunch of SS15s is the way to go, but I want to see if this makes sense to those in the know: I have 6x Delta 12LFA on hand, bought for dirt cheap after coming accross plans for some tall horns starting with T. After procrastinating for a while and reading around, I've been swayed away for a few reasons, and my goals have changed a bit. The new plan is to build a battery-powered sound system, that is moderately portable and versatile. A couple of hand trolleys/sack trucks, with a stack of batteries (low for balance), a few subs, then tops above head height, would make the stereo pair that can be used as portable system on the move for parades and the like. When stopped and set up, the subs can be lumped together and the trolleys are kept as speaker stands for the tops. Probably sounds silly, but we have some pretty good street/laneway/park parties here (Newtown/Marrickville) every year, Reclaim The Lanes being the biggest and that's in February - giving me a goal to work towards... I'm set on the SS15, not because it's the "best" for my purpose as a few reflex boxes would probably work really well for my bass duty... but how cheap, light and simple this design is makes sense for expanding the system in the future when it becomes more than just a rig on wheels. The gains from "barn door" additions as made by r23d (posted here) is a big appeal, the panels could strap on the sides of the system when it's being wheeled around and when it's parked in a park, they can be bolted together for something bigger and louder again. The limitations of working with 24V battery power outdoors means I'll only be putting 24V max (probably ~22V) in to the drivers, and only need response from 60ish up, pursuing anything lower is futile. When I modelled the D12LFA using DJIMs numbers shows the driver seems to perform OK in an unmodded box, and runs out of xmax at 22V. Happy coincidence! It all seems to be a good idea so far... Long winded intro, sorry, I'm bored at work and full of ideas... the point this post is to ask: Are my numbers for simming the D12LFA close to accurate? It's the first time I've used HornResp Would I gain/lose anything by making the box slightly narrower, perhaps 19.5"? And are there any other mods to the box needed for running the 12" instead of 15", ie, does the driver mount off centre on the baffle or anything like that? I'll try and build a test box in the next month or so to see if it works out, and if there are any small changes to make I'd like to factor them in... |
#1812 |
#1813 |
Even though this is an international crowd i still want to wish everyone a happy thanksgiving! How is this pertinent you may ask?
Big thanks to Mr Jbell for initiating and nurturing this excellent discussion and all of the other great minds for their contributions! ... Such fantastic examples of innovation and collaboration should be celebrated !.. I have some questions for Mr Bell, and actually Bitsmasher has already sort of beat me to the first question, its about hornresponse inputs ... Are the inputs in Bitsmasher's example (in the above post) the most current inputs? Because i also use those very same numbers to simulate the SS15 cabinet and i want to make sure that i am up to date ![]() Excellent design by the way, so small, lightweight, affordable and great output covering the most important portion of the bass range when it comes to reproducing the majority of music ..... The most adept of hornresponse jockeys could push pixels all day long and never come up with an improvement to your box, at least not without having to make some major sacrifice in one area or another...... Did the SS15 version 2 with the cone compensation improve upon your original design at all? I never did hear much about the results or see any charts ... Jim, i have seen you mention in this discussion that you would like to see a little more output at 40hz.. It would be like adding a giant cherry on top of an already superb product... Adding a little extra bass extension to this box has been the focus of a few of my recent hornresponse tinkerings... I'm a novice but i did observe something interesting that might be useful ... When i was plugging a few different drivers into the SS15 i spotted a pattern .. I noticed that a few drivers that had very low VAS values, lower QTS values and higher BL values such as the RCF LF15G400 and the B&C 15tbx100 would allow the SS15 to play lower .... You have to add "LE" to smooth out the response (totals of 4 or 5 millihenries including driver inductance) ... The end result being a sacrifice of a few DBs at 65hz to gain 3 decibels at 40hz , but i think the best part is that the "knee" point at which the response drops off sharply shifts down by 10hz! Forgive me if someone in this forum has already mentioned this... I have to wonder if this is the same method that Mr Danley uses in some of his boxes because i have heard that large inductors are used in some of his TH cabinets and he also seems to use some drivers with high BL factors ... |
#1814 | |
if you narrow the box you wil always lose low end and/or efficiency. mods are not needed ,but you wil gain a bit round 60 hz by making s2 a bit smaler. (try s1 300 and s2 350) i would put the driver as far back as posible (shorter s1>s2 and longer s4>s5)
one good thing about music ,when it hit you feel no pain. so hit me with music.
#1815 |
if you just rotate the speakerbafle (fixed to the front) ,so s1 becomes 2,5"instead of 3.5",
and put the driver as far back as posible,you get this.
#1816 | |
Can you elaborate a bit on how you use the torx head deck screws to assemble the wood, also... is it better to use torx than hex head screws or why you gravitate towards torx? do you use a power tool like a cordless drill with the screw attachment to secure the panels ? i do not have those clamps and if i can build without clamps it would be a plus Thanks Max. Last edited by maxo; 22nd November 2012 at 10:26 PM. |
#1817 |
They don't snap like drywall screws
They don't strip as easily as Philips head screws Most boxes come with the correct torx bit to use. |
#1818 | |
screws and boxes i googled but there are sooo many flavours i dont want to get the wrong ones |
#1819 |
I have had good luck with deckmate brand from Home Depot.
Deck Mate, #7 x 1-1/4 in. Coarse Green Coated Steel Flat Head Exterior Wood Screws 1 lb. Pack, 12125 at The Home Depot - Mobile |
#1820 | |
so you just use the screws to make the "box" and the insides panels are just glued or you screw all parts in then super PL all joints |
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
