Single sheet TH challenge - Page 174 - diyAudio
Old 8th October 2012, 05:35 PM   #1731
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Originally Posted by Djim View Post
Monacor SP-15/500FH (not available in US)
This driver is OEM'd by FaitalPRO, it's a 15FH500 if you are interested...
Dan
Old 8th October 2012, 05:54 PM   #1732
Djim is offline Djim  Netherlands
Thanks Dan, more series in the Monacor line are made by FaitalPro. Btw all Monacor drivers are produced elsewhere.
Old 8th October 2012, 07:01 PM   #1733
Send a message via AIM to shon35us Send a message via MSN to shon35us Send a message via Yahoo to shon35us
Can anyone tell me where I can find books on making this type of enclosure?
Old 8th October 2012, 07:15 PM   #1734
maxo is offline maxo  United States
Other drivers for the SS15:
Ande LB15-1 (not available in US)
Ande LB1560 (not available in US)
B&C 15PZB40
DAP AB-15 (only available in Europe)
Eighteen Sound 15W600 (no longer available)
Eighteen Sound 15W700
Eighteen Sound 15ND830
P.Audio C15-600EL
RCF L15P200 (no longer available)
RCF L15P200AK (NOT the new L15P200AK-II version!!!)
Cheapest driver: DAP AB-15 for 50 Euro.
Great DJim
i would like to make a homebrew list of all of the drivers
and post from lowest to highest price and from lowest to highest power
and sorted by weight also... maybe a bit redundant but want to save time
to other guys who want to build and need stuff in a hurry
well... that is just an idea and i want to see what the members of the board here think about it
Max.
Old 8th October 2012, 07:17 PM   #1735
looks like those are Italy made drivers right ?
what about Fane
does Fane make a suitable driver for the SS15 ?
Old 8th October 2012, 08:59 PM   #1736
Hi there S: The SS15 was origionated by "JBELL" and posted here, see post #1. Everything a DIYer needs to know to build them is in this thread, so spend the time to read/understand the information in the thread, it's quite a story in itself. There are several other builders who have written about their experience building/utilizing SS15's. enjoy....Michael
Old 8th October 2012, 09:04 PM   #1737
Ok, thanks I will look that up
Old 9th October 2012, 12:26 AM   #1738
found this peavey 15" driver that suppose to withstand 1200 watts RMS....
can anyone do a sim with the SS15 and see if it would be feasible
to stick SS15's with this driver
it costs 325 each
Peavey 15" Lo Max Subwoofer Speaker - Peavey 15" Lo Max Speaker - Peavey 15" Lo Max subwoofer speaker - This Peavey 15" Lo Max subwoofer handles 1,200 watts RMS.
Resonant Frequency (fs) 38.2 Hz Impedance (Re) 6.1 ohms Coil Inductance (Le) .829 Electromagnetic Q (Qes) .364 Mechanical Q (Qms) 11.018 Total Q (Qts) .352 Compliance Equivalent Vol. (Vas)
125.7 Liters/4.4cu. ft. Displacement Volume(Vd) 87.1 cu. in. BL Product(BL) 23.6T-M Voice Coil Overhang (Xmax) 8.25mm Reference Efficiency % 1.86% Surface Area Of Cone(Sd) .084m2
Old 9th October 2012, 12:55 AM   #1739
jbell is offline jbell  United States
workable, yes. A couple db down vs the eminence in the 50-70hz range, and more expensive... It is out of xmax at 500 watts, However it does work.
The 4015lf is $100 cheaper from the same retailer....
Old 9th October 2012, 01:46 AM   #1740
also dont forget the JB1500N as a suitable driver
im yet to run my 4cabs outside, but facing out from inside a garage they were absolutely amazing, good deep rumble, with plenty of kick and punch going on.
then on the flip side, i had the opportunity to run them in a sports hall the size of two basketball courts, and severe lack of deep (sub) bass outside a 20m perimeter, but a ton or smacky punch throughout the venue.
overall, im very happy with my JB1500N loaded SS15 kit. and cant wait to build more!!! FlipC's Dozen is my inspiration!!!
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
Copyright 1999-2017 diyAudio
