Single sheet TH challenge
Old 27th September 2012, 11:06 PM   #1701
CRESCENDO is offline CRESCENDO  United States
Yep, that'll work great for the budget minded
Old 27th September 2012, 11:09 PM   #1702
maxo is offline maxo  United States
Actually for the budget wallet
my mind want the most expensive driver
Old 27th September 2012, 11:51 PM   #1703
I know the feeling...
Old 27th September 2012, 11:52 PM   #1704
klampykixx is offline klampykixx  Australia
thanks for the power/spl/db info. i kinda knew that, but now its clear.
when i was talking percentage, i was referring to max excursion. since thats the defining point of the music i play. if it had 10mm xmax, and i run it at approximately 9mm, thats the 90% im referring to. but yes. DB is probably the better way to measure, i just havent ever worked with those measurements ever before. so got no reference to it.
on a different note, im doing a birthday gig on saturday, in a narrow shed (double bricked on both sides) its approximately 5-6m across. would you stack subs together or upright in this case?
do ya think stood up like this?
or stacked
Old 28th September 2012, 12:11 AM   #1705
Djim is offline Djim  Netherlands
Originally Posted by maxo View Post
i plan 4 ss15's , wired in parallel so the array will have an impedance of 2 ohms since my crown per the spec sheet says it can deal with 2 ohm loads
Hi maxo,
Usually 3 drivers in parallel give around 2 Ohm. 4 drivers will end around 1.5 Ohm and most amps are not build for that load.
Old 28th September 2012, 12:14 AM   #1706
Djim, i was always taught that it halves?
2x 8R in parallel, = 4R and then two 4R pairs will equal 2R???
Old 28th September 2012, 12:18 AM   #1707
jwmbro is offline jwmbro  United States
jwmbro's Avatar
But it's not 8R in the first place, it's more like 6R. So two in parallel are 3R and four in parallel are 1.5 Ohms... pretty low load.
Regards, James
Old 28th September 2012, 12:19 AM   #1708
ok that makes much more sense.
Old 28th September 2012, 12:52 AM   #1709
Originally Posted by Djim View Post
Hi maxo,
Ohhh ic, so with 3 i can get max juice out of the amp
Thanks for the info man
Max.
Old 28th September 2012, 01:12 AM   #1710
Looks like both problems are fixed
Single sheet TH challengeHide this!Advertise here!
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
