Single sheet TH challenge
Old 27th September 2012, 12:44 PM   #1691
CRESCENDO is offline CRESCENDO  United States
Originally Posted by Etocynned View Post
As far as control goes where in the signal cnain is the "volume" knob?
From what I remember reading, his "volume" knobs are his amps - which is how it should be (in his case, especially). He's got channel faders on his DJ mixer to turn his audio material down.
Old 27th September 2012, 01:41 PM   #1692
klampykixx is offline klampykixx  Australia
Cressendo is correct in this instance.
When i set up my gear at each gig i always start with the tops. i get them to a reasonable level to eq them and then set max volume via the mixer so max is just under clipping on the mixer not the amp. Then i bring the subs to where they sound right with the tops and thats pretty much set then. I can drop levels at mixer level and bring them up knowing ill never go over as long as im not clipping the mixer.
Hows that?
Old 27th September 2012, 01:58 PM   #1693
maxo is offline maxo  United States
Hows that?
but how do you know how many watts are you sending to your tops
as on an earlier post you said you blown one of the tops
so how do you calibrate to set the tops in a way that even with your mixer all the way up
you are not sending deadly watts to them....
just a thought...
Old 27th September 2012, 02:09 PM   #1694
I dont know how many watts. But i did say i broke. Not blew my tops. A jerk stood on the cable n tore it out of the cab.
The subs i blew coz they were cheap china crap and couldnt handle the power. When i set it up that time there was no distortion but they were maxxed out and just got hot and failed. That was when i had the sub amp at over 3/4 on the dial. I have never blown a top end speaker. I hate the sound of distortion. And very much pride myself in my sound quality aspect. I always give myself about 5% headroom as well. Just the cheap subs got hot n couldnt handle it. 300w subs sucking on 800w+ is never going to end well. Hence the new JB1500N 600wrms each. Should be fine.
Old 27th September 2012, 05:19 PM   #1695
weltersys is offline weltersys  United States
weltersys's Avatar
klampykixx,
If you start thinking in terms of dB (decibels) rather than percentages you can more easily grasp what is happening in terms of power.
A three dB increase in gain doubles power, which could be construed as a 100% increase. "5% headroom" would then mean only .15 dB headroom, effectively none (about 17 watts if 800 watts is considered "100%").
As has been pointed out previously, the taper on amplifier gain knobs are all different, halfway or 3/4 is meaningless, it is the decibel ratio that is important, and fortunately all professional amp's gain controls are labled in dB, making setting a system's gain structure relatively straightforward.
It takes a 10 dB increase in SPL (sound pressure level) to sound twice as loud at 1000 Hz, but that increase requires 10 times the power.
Doubling speakers gives a 3dB increase in efficiency, so the same level can be achieved with half the power going to two speakers, 1/4 the power per speaker than a single.
With power compression from voice coil heating often robbing 3 dB from a speaker such as is usually used in the SS15 when run near rated power, doubling cabinets may actually net more like 1/8 the power requirement.
Art Welter
Old 27th September 2012, 07:53 PM   #1696
Well explained Welter
i plan 4 ss15's , wired in parallel so the array will have an impedance of 2 ohms
since my crown per the spec sheet says it can deal with 2 ohm loads
i will try it as it is rated at 1kw at 2 ohms
i will use one channel for the subs and the other channel for the mains 4 full range 8 ohm cabinets that will go to 2 ohms wired in parallel
but right now
i only got the amp , one old full range cab and a chinese crappy sub that i will send back
i already see the price of a sheet of 1/2 birch plywood on homedepot it cost 37 bucks ( plus tax )
so... the thing is that i dont think i can cut the plywood in a nice manner...
i can glue and assemble but i am not good with the electric saws , and i dont have those nice table circular saws to make perfect 90 degree angle cuts or the angles needed
for the internal panels and brassings
is there any member here than can offer to make the cuts so you end with a DIY kit ( with the birch parts already cut) and charge accordingly of course, nothing is for free in this life
i wonder if there is a competent shop here that can cut to the spec with the plans...
this little town dont have nothing but broker warehouses
Old 27th September 2012, 09:30 PM   #1697
I might be able to help you out, but I think shipping would add on a significant expense. Home Depot usually has a lumber cutting service available (they charge per cut, after a couple free cuts) - that may be quite a bit cheaper than just the shipping alone.
Old 27th September 2012, 09:41 PM   #1698
Thanks Crescendo
i really appreciate your gesture
i will look in to home depot and see if they can do the cuts
is there some list for the SS15 that says
1 bag of #2 philips screws
3 tubes of wood PVZ cement
1 jar of speaker enclosure lube
to say some
Old 27th September 2012, 10:48 PM   #1699
It depends how detailed you want your cab(s) to be, but it's more like:
Per enclosure:
1 - 4x8 sheet 1/2" aurauco (or better)
1 - tube 10 oz. PL Premium Construction Adhesive
1 - box of #6 (or #7 - can't remember which I used) 1" coarse thread screws - I prefer square drive (remember to pre-drill)
1 - Speakon jack plate (or 1/4", but I highly recommend Speakon)
2 - NL4 Speakon connectors
4 - female disconnects (16-14 awg .187)
4 - shorter screws to mount Speakon plate to cab (#8 x 1/2" deep thread pan head will do)
4 - machine screws to mount speakon connectors to jack plate #6-32 x 1/2" (Home Depot: Crown Bolt 28311 (discard the nuts they come with - won't fit)
4 - nylon lock nuts #6-32 (Home Depot: Crown Bolt 19231)
8 - screws -or- bolts, nuts & washers to mount driver (I like using these with the appropriate machine bolts - take one to HD and find your fave)
1 - can Plasti Wood (to fill in screw holes after removing)
Speaker wire
Duratex (for finish)
Handles
Feet (optional)
Corners (optional)
Grill (optional, but HIGHLY recommended)
Anyone, feel free to add info I've missed
Old 27th September 2012, 10:52 PM   #1700
ohh that is a nice list crescendo
and one of this right ?
Eminence Kappa Pro-15LF-2 15" Cast Frame Driver 290-420
Single sheet TH challengeHide this!Advertise here!
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
