Single sheet TH challenge
Old 20th September 2010, 09:10 PM   #161
jbell is offline jbell  United States
Originally Posted by Don Snyder View Post
Thanks Jim,
As good as HornResp is, it doesn't sim everything. I am surprised since my first TH was OK and Anders' horn was reported to sound so good. I may build
one and attempt to fix it by trial and error, but I'm no Screamer.
I wish Tom would critique some of these boxes, but that's asking the guy to cut his own throat.
I work with "Relay for Life" and plan to build up a PA to loan out. The Crown XTi 2000 looks like a good way to go. If you have any hints, please e-mail me.
~Don
I walk relay each year, and always cringe at the 15+comp cabinets with no subs that always show up... However walking all the 80's music they always play is fun with friends.
The 'key' to a good sounding TH in my opinion is to minimize parallel walls/standing resonances, and to minimize similar path lengths. It's kinda like playing a chord on a piano. The richer the chord, the fuller the overall sound.
Old 20th September 2010, 09:46 PM   #162
CuttaBoi is offline CuttaBoi  United Kingdom
Originally Posted by mike james 533 View Post
Hi CuttaBoi,
Sorry to say no more news yet. A few weeks ago I fell and broke a couple of ribs. I was starting to heal up pretty good and got 2 sheets of ply cut. The next day I turned my ankle over and fell again. I injured my ribs again and upper back.
Just as soon as I can get healed, I will get the build going again. I can't tell you how excited I am to get them completed. Will be glad to replace the W-bins we use now. Sorry for rambling on.
Don't give up on me and the build, it will happen and I will post pics and reports on performance.
Thanks Mike
Ouch, really sorry to hear that mate, Hope you get well soon.
Old 20th September 2010, 10:20 PM   #163
GM is offline GM  United States
GM's Avatar
Originally Posted by jbell View Post
I'm curious, I just 'ran the numbers' on this TH WRT HR path-length and end loading, winding up at ~409 L Vs your ~ 573 L, so was wondering if the little extra calculated SPL it has (gray trace) is really worth an extra ~164 L for its intended app(s) and whether or not you think this driver can safely handle its bit higher ~1.762 Vs ~1.124 CR?
TIA,
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st September 2010, 02:30 AM   #164
gm:
If your hornresp was on the 2x2x4 box shown in that link -- I don't like it, and won't build another. It's personally not worth it to me to refine it. It was a 150lb experiment, that while salvaged for the intended install with a couple reflectors... it did not achieve what I was looking for -- A cheap, easy, quick build that would satisfy a large number of the installs I have to do.
The single sheet design does that for me. It's the cabinet I'll build in the future.
Old 21st September 2010, 05:01 AM   #165
GM's Avatar
Right, you linked it, so thought it was the one folks were referring to since I haven't been following this thread regularly.
GM
Old 21st September 2010, 06:59 AM   #166
salzburgsoundsystem is offline salzburgsoundsystem  Austria
Default could you use this, or are the specs unsuitable? LAB 15 at 70% discount
Eminence Lab 15 High-Power 15" Subwoofer and more PA Cabinet Parts at GuitarCenter.com.
saw this on the other forum and I thought of you!
Ben
Old 22nd September 2010, 03:53 AM   #167
Brian Steele is offline Brian Steele  Grenada
Originally Posted by salzburgsoundsystem View Post
Whoa -that's a HUGE price drop! Has anyone done a TH around that driver?
Old 22nd September 2010, 04:52 AM   #168
mike james 533 is offline mike james 533  United States
WOW that is a great price! About $100 below wholesale pricing. Wonder what is going on that they dropped the price that much? The big E must have lost a big order buyer or something.
How would the LAB 15 do in a SS-15?
Old 22nd September 2010, 05:36 AM   #169
GM's Avatar
Indeed! ~$100 delivered to my door. Wish I could take advantage of it.
Just sims...........
GM
Old 23rd September 2010, 06:18 AM   #170
martinsson is offline martinsson  Sweden
There is a "MKII" of my THAM15 (aka andershorn) in the works, the modifications is based around four 45deg. refelctors positioned in the horn path, one of wich also acts as a chamfer at the mouth increasing S4 by a factor of approx 1.2 and slightly increasing L34.
These changes are along the lines of what William and I once talked about some time ago but i did not act on it, but now a friend of mine here in Sweden has offered to try this mods out and compare them to the original design in an atempt to improve the design.
Hopefully these changes will result in a slightly higher over all effeciency and supression of the 180Hz dip, but this remains to be seen.
Single sheet TH challengeHide this!Advertise here!
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
