#1651 |
#1652 |
Ive searched through the thread and only found i few 4ohm driver recommendations.. Any thoughts on which driver to match the design like the 3015lf do? Have been looking at the B&C 15NDL76 & Fane collosus 15XB. Im not too bothered about the weight, as long the box is getting the highest spl possible. Am I on the right track or would other drivers be a better choice?
#1653 | |
#1654 | |
I did some quick amp tests (also posted in the TH-18 thread) in briged configuration and found the voltage out was less than half of the rated power with the clip limter engaged and the clip/limit light fully illuminated (heavy into it). When I measured my SS15 just under clip (light flickered), the amp was not bridged and the clip limiter was on. Just food for thought (and I hope to test with SPL AND actual voltage numbers the next time) |
#1655 |
^ on a crown XTI?
#1656 |
Actually, PLX3402 clip test
#1657 |
not directly relevant to the SS15 cab, but since its the driver thats going into mine, i figured id post up what ive just done to start the break in process.
JB1500N break in 30-50hz sweep - YouTube |
#1658 |
After doing plenty of research on different ideas for a PA subwoofer, I landed here. I tried jumping around from the first page, but decided to skim all 166 pages. Now that my eyeballs can focus again, I decided I needed to post up...
First: Thanks to all involved! This is a great project with a lot of community support. Now then, I feel a bit confused on what design to go with. There seems to be ~3 versions of this... 1. dbell's original (post #53) 2. Djim's "extended" (post#691) 3. dbell's "SS15v2" (post#1499) Is there a comparison of the 3 directly? I saw some original vs extended comparisons... It seems the v2 is pretty new and I don't think I saw it tested? Sorry, if this information is all pretty available, I'll be happy to go more read-happy on this thread... just took a long time just to skim through all those pages! Or perhaps, a general consensus on which one to build? I just to hate to build one to find that it isn't as solid of a build as another. Thanks for whatever information can be provided. |
#1659 | |
#1660 |
The original works so well -- just build that.
Use the 4015lf if you plan on abusing it. Use the kappa pro 15lf2 for a budget, lower power option. If budget is concern, I'd rather have a pair of kappa pro loaded cabinets, vs a single 4015lf cabinet. 32hz 24db/oct high pass. The high pass is not an option. |
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
