Single sheet TH challenge - Page 163 - diyAudio
Old 13th August 2012, 11:50 AM   #1621
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Originally Posted by AndrewT View Post
What are you calculating?
nothing of any use... lack of sleep I guess
At any rate djk has the scoop and so the coil length would need to be ~29.5mm long to get to 11mm x-max. The slice of magnet is 25mm thick, that driver better have a HUGE bump on the backplate... I doubt that it does, and I doubt that the coils is that long... It's probably like my bad math example above
The new Faital 15HP1030 can push itself to x-dammage, I gave one a good whack the other day, oops , it's alive and well though.
Dan
Old 13th August 2012, 12:08 PM   #1622
djk is offline djk
djk's Avatar
"Lies and damn lies seems little different from disreputable manufacturers' claims when it comes to audio product. "
Sure, if you say so.
You totally don't understand the 70% Bl specification.
The newer JBL models with the 12.7mm top plates have very low x-max by your method, but lay waste to the older models with the 8.1mm top plates.
The 70% Bl estimation with the the gap height/4 method also correlates well with how it sounds in practice.
Whatever.
Candidates for the Darwin Award should not read this author.
Old 13th August 2012, 02:43 PM   #1623
I wanted to thank jbell and jwmbro for great advice in adapting the ss15 into a 12" driver, slimmed down version:
~50 lb tapped horn, woofer under $100, high efficiency, low power?
I'm usually a big advocate of time correction of bass, but it looks like I won't have time correction in the system I'm currently thinking of for this, a portable PA using a class-d car amp. Can you get away without time correction here? I found the group delay sim earlier in the thread, see below. Figure that the mains are bass reflex with a high tuning (some group delay already), and active crossover at 80 to 100 hz which could be tuned for an overlap or gap, plus a parametric EQ. Do you think the integration will be pretty clean without time correction, assuming physical alignment? Thanks!
As a side note, has anyone run FIR room correction on a horn sub...?
TH-18 Flat to 35hz! (Xoc1's design)
Old 13th August 2012, 07:05 PM   #1624
Obviously I don't understand.
I didn't know it existed, nor did I see a need to corrupt the Xmax definition.
Your explanation has helped in drawing my attention to some new standard. Does someone want to take the time to refer me to a paper or other documentation that shows what the new dimension does for us and why we need to know it?
Now it looks like there is a new definition of stroke/travel that is bigger than Xmax but which lies within a tolerable limit.
What do you call that new stroke dimension?
It can't be Xmax. It must have some other non ambiguous title.
Does it incorporate the 70 that you have mentioned?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th August 2012, 02:58 AM   #1625
Djim is offline Djim  Netherlands
Hi Andrew,
I think what Djk meant is that the BL value drops as soon displacement starts.
However, Klippel proved there is no simple relation between BL and Xmax. He also showed there is no simple relation between harmonic distortion and Xmax either. In reality this means, even when Xmax is reached it does not guarantee that the excursion is really effective in 'usable' dB's. On the other hand there are also manufacturers that produce drivers with an Xmax that can be exceeded far beyond and still having large amounts of linear displacement in the right enclosures.
Xmax figures are usually food for misconceptions. Each driver has its own specific properties and each driver responds different to their load. Therefore is Xmax nothing more than an indication. Knowing the brand and its reputation and knowing the way they measure Xmax usually helps to expect what might happen. Measuring the real thing (in dB’s instead of mm) is the only guarantee.
Old 15th August 2012, 02:47 AM   #1626
For all you aus speaker builders, what do you think of building with form ply? I was planning to use 18mm form ply if i could get away with it. Its dense and laminated each side.
Old 15th August 2012, 09:38 AM   #1627
Mark Kravchenko
mwmkravchenko's Avatar
If you are referri.g to the fir plywood that has kraft paper bonded to two faces then go for it. It's good stuff. Used lots of it.
Mark
www.kravchenko-audio.com
Old 15th August 2012, 10:49 AM   #1628
Im not sure If it is the same thing, but if it is then that's good news. Here in AUS its $80 for 2.4m X 1.2m sheet, compared to marine ply (next best aus thing to baltic birch) is $190+ for the same sized sheet. I thought the fact that its laminated may help reflecting sound through the box a bit better and may also help resonances due to probably being inferior to marine ply (maybe).
Old 15th August 2012, 10:55 AM   #1629
Mark Kravchenko
I'm guessing it is the same thing. Concrete is pretty much the same thing no matter where you work with it. The plywood is pretty much void free.
Keep in mind I have built with OSB (strand board) and cheaper poplar industrial plywoods with good effect. Keep your box well braced and you will do fine with most sheet goods.
The stiffer the box the higher the efficiency.
Mark
Old 15th August 2012, 11:05 AM   #1630
Well I figured being thicker at 18mm thick should help and will also do a lot of bracing too.
Four JB1500 drivers and a crown ITX4002 have been ordered :-)
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
Copyright 1999-2017 diyAudio
