Single sheet TH challenge - Page 160 - diyAudio
Old 28th July 2012, 04:18 AM   #1591
Djim is offline Djim  Netherlands
Originally Posted by Djim View Post
Acoustic-air only reacts to volume in relation to its position on the horn-path. If that wasn’t the case we couldn’t use braces at all.
Small correction: "Acoustic-air" should be "The cone".
Old 28th July 2012, 04:59 AM   #1592
nobody answered my Q, about the smaller baffle cutout offering any amount of compression. is it worth attempting to cut out the baffle to suit?
the other alternative, is to leave it as is, with the 12inch driver.
please help
Old 28th July 2012, 02:06 PM   #1593
tb46 is offline tb46  United States
Hi klampykixx,
Posts #1592/1585: "i currently have a 12inch driver in it. so it has a 12inch hole. i want to use a 15inch driver in it but dont think i can get a jigsaw in there to make it 15inch. so its either leave it as 12inch, or make a standoff ring 15inch diameter"
You should be OK with an adaptor ring: make an adaptor/standoff ring to fit the 15" with enough room to prevent the cone/surround from hitting the wood.
If you want to know what it does at low levels: enter the driver data and horn data into Hornresp, measure/calculate the throat chamber details, and enter them into Hornresp as Vtc/Atc/Ap1/Lpt.
If you have trouble working with Hornresp go here: Simple Tapped Horn Tutorial using Hornresp .
Oliver
Old 29th July 2012, 02:30 AM   #1594
thanks TB, ill suss it out.
Old 31st July 2012, 06:47 PM   #1595
jwmbro is offline jwmbro  United States
jwmbro's Avatar
And done (for now!).
Can't wait for the first full power field test on the weekend, then I'll finish em in texture paint if I'm happy with everything.
One SS15 and two (sort of...) HS12
Damn the Kappa Prof 15LF2 is heavy. Going to have to look at paying the 100 bucks extra for the neodymium 3015LF. I think it's worth it for the weight savings and the extra xmax.
Regards, James
Old 2nd August 2012, 06:18 AM   #1596
got any more info on those top cabs? ^^
here is a trial session of my gear. just waiting for my new JB1500N drivers. ordered two. due friday 3rd august.
the center cab is an SS15 design, with a Fusion car audio sub. EncounterHD 12inch. ENSW12HD.
http://s930.photobucket.com/albums/a...2082012010.mp4
sorry about the crappy quality.
Old 3rd August 2012, 07:06 AM   #1597
got my JB1500N's today
just had em pumping for a brief period at what i think was about 70% of what theyre capable of. must say, im quite pleased with them. they sound solid thats for sure.
i must admit tho first impression tells me theyre not as deep as the old china subs i had. but they should get deeper as they run in. theyre pretty stiff.
anyone recommend run in tracks?
Old 3rd August 2012, 07:31 AM   #1598
djk is offline djk
djk's Avatar
Position Music, Inc.
Candidates for the Darwin Award should not read this author.
Old 3rd August 2012, 07:44 AM   #1599
just checkin it out now, i presume its the lack if distinct percussion, and lots of pure rumble that youve recommended it djk?
Old 3rd August 2012, 09:48 AM   #1600
djk is offline djk
djk's Avatar
It's just noisy movie music, lots of percussive noise in the bass.
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
Copyright ©1999-2017 diyAudio
