#1581 |
#1582 |
#1583 |
i have a question regarding just my first built cab.
i built it as an SS15, but knowing i was only using a 12inch driver. this particular cab is active, so has the amp on the back, what im wondering, is that the amp has potential to drive this one cab differently to two others even with the same driver in it. so, if i do decide to keep it as a one off for smaller gigs, im thinking about leaving the 12inch hole as is, but putting a spacer ring on it so i can still fit the 15inch driver and not have the suspension slap the baffle board. will having a 12inch hole act like a compression chamber? how would i be best to simulate this on HR?? |
#1584 |
Do it the other way around. 15" hole and use a 12" adapter plate.
#1585 |
i currently have a 12inch driver in it. so it has a 12inch hole.
i want to use a 15inch driver in it but dont think i can get a jigsaw in there to make it 15inch. so its either leave it as 12inch, or make a standoff ring 15inch diameter |
#1586 | |
Any more on this? |
#1587 |
i was looking at this
![]() this cone corection is only 2 dimensional a cone has 3 dimensions. i think creating a chamber would help to save the cone(at the expence of a dip above 100 hz) ![]() mij new project is a conical rectangular th with chamber with the 18 sound 21nlw9000. chamber size depending on the 8 or 4 ohm version>depending on wich amp. probaply powersoft 3000pfc or pwr dsp1
one good thing about music ,when it hit you feel no pain. so hit me with music.
#1588 |
EPA or anyone else... how would I take that design and plug it into HornResp??
For example if I wanted to tweak the SS15 on paper, how do I translate the s1, s2, s3 numbers to get an estimated response? Reason I am posting here and not in another thread is because I also want to help out with calculations while learning more about hornresp and TH Design...
The best DJ in Houston using the SS15 born in diyAudio from Jbell and the rest of the community!! |
#1589 |
Oliver |
#1590 | ||
Cone correction doesn’t need to be three dimensional. Acoustic-air only reacts to volume in relation to its position on the horn-path. If that wasn’t the case we couldn’t use braces at all. Quote:
Never worked with that driver but it looks like a 'heftig dingetje' ; |
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
