#1541 |
Hi Phil B,
If you made a Hornresp model, did you change it to a TH1 model by double-clicking on TH? That way you can add your horn extension as S4/S5. You may then have to use Exp for the S2/S3 horn segment as this horn has multiple tapers. Regards,
Oliver |
#1542 | |
Indoor room modes often dominate low frequency measurements. Move the microphone or the speaker around and the response will change. The indoor warehouse response simply reflects the "boom boom room" effect, their previous outdoor tests match the "normal" SS15 response pretty closely, as can be seen in the two screen shots of the same speakers below. Left is in the warehouse, right is outdoors. Last edited by weltersys; 22nd May 2012 at 02:03 PM. |
#1543 |
Hi
I`ll have to ask Mr Rich ( R23d) about the hornresp modelling, he plugged in most of the data and we only made some small changes to match the RCF drivers. As for the difference between indoors and outdoors I`ll have to go back to my statement of Holm Impulse giving us some very strange readings. It seems to fill in the gaps until it gets stable enough to plot properly. The REW measurements are very good and reflect what my ears think the boxes are doing. We tried running full range sweeps with Holm on the Unities and Subs combined outdoors. It just couldn`t give us an accurate reading with all the passband gains set at relative volume, it would seem to latch onto the highs and ignore the subs / mids. NOW I must confess I hardly know the program and was intrigued to try it out. Again if I had the time to sit down with it and work out why we getting these results I`d love to! BUT time meant we moved to REW and now have two sets of results on two different measurement programs......not ideal or helpful!! The warehouse we measured in was VERY big but full of clutter. Also we measured from 3-4m away on initial runs. So even with the mic pointing at the floor from < 1cm we might have got some room modes.The very first measurement runs were made with temp barn doors on one box at about 2am....not too scientific! I personally am very happy with the result the doors give. We knew the subs were never going to reach 35hz or be 6db louder with them but they have added a simple, cheap way of getting nearer to that! Phil B |
#1544 |
Hi Phil B,
Do you have indoor measurements of the same setup without the "barn doors"? |
#1545 |
As a new person to this site I just want to say thanks. This thread is an example of the collaboration that is the very best of the internet. I plan to build four to six of these this summer as a church youth group project. I am trying to create an initial lead booklet on the project for the kids and this thread at over 150 pages and 1500 posts has become a monster to navigate and extract the latest/best information from. Would it be possible to pull out and collect at the top of the thread:
1)The latest cutsheet 2)Recommended materials including adhesives and finishes 3)Assembly tips including where additional bracing may be wise even if they don't come out of a single sheet 4)Tips on finishing 3)Thoughts on best locations and options for handles, pole sockets, input panels. 4)Recommended drivers, response simulations for those drivers, real world measurements for those drivers 5)Recommended signal processing and amplifier power Again this is a thread for the ages thanks to all the collaborators. |
#1546 |
I echo Dynamic's request.
An index in post1, showing links to the best bits of information would be really helpful to everyone reading this Thread. |
#1547 | |
moderator? please?? |
#1548 |
ahhh... THANK YOU... I now see an 'edit' on post 1.... Anyone with votes for favorite posts, let's hear them. In a couple days I'll compile a list of the best, and put it in the first post.
#1549 |
Jbell,
the edit first post feature was brought in many weeks ago. You don't need to ask the Moderators. |
#1550 |
...truth seeker...
jbell, Thank You...the editing into post #1 has begun
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
