#1521 |
Hi jbell,
What is the distance between boards H and E? Regards,
Oliver |
#1522 | |
Nice work! Your extender adds more path length and is larger relative to mouth size than the ones I use, adding more gain and also lowering the Fb. Mine were designed to assist the low mid in my system, the extra 3 dB they provided down to Fb was a bit of a surprise. The great thing about the added 4 dB (and lower frequency extension) an extender provides is it is not subject to power compression. The SS15 has nearly 7 dB of power compression at 700 watt input compared to one watt, the extenders allow reaching a higher output level with a fraction of the power. Did you happen to try the extender expanding from the full frontal area of the SS15, rather than just the mouth area as pictured? Art Last edited by weltersys; 19th May 2012 at 06:09 PM. |
#1523 |
#1524 |
The only difference between extending the whole front instead of extending just the mouth is that if the cavity becomes large enough it can create its own resonance (peak in response).
#1525 |
#1526 |
I'm not anywhere close to my shop, (it's graduation weekend for family member) but from memory.
The last ss15 layout I posted is 107" total path length. 3.5" to start at S1, 4.5" upper left, 6.5" upper right, 9.25" bottom right, 16" opening. Should be able to reverse engineer the hornresp inputs from there. H and E are about 1" apart Last edited by jbell; 19th May 2012 at 08:41 PM. |
#1527 | |
Please show me your actual measured response showing a resonance peak being the only difference .Until then, I'll await Richard's response to my inquiry. Art |
#1528 | |
The graph I posted should only be taken as a relative comparison, because we did not use an SPL meter to calibrate outputs to 1w/1m or anything so useful. For the graph posted, I used a behringer measurement mic (ecm8000 I think) about 2m away on the ground in my reasonably large backyard. I expect the results are a bit lumpier than we would get in a nice open area. FYI we're using Room Eq Wizard v5 software to do sweeps - free download from Home Theater Forum - Home Theater Systems - HomeTheaterShack To work out the best shape for extended response, I made some big guesses using hornresp, and then we expermented by sitting one sub on it's side with a board on top, placed side panels in at various angles and sat on them Not hugely scientific I know, but we tried quite a few shapes quickly this way, and this setup gave us pretty good results. Other tidbits : - We wanted to keep the mouth open for simplicity and visual appeal, so I'm using aluminium channel to stiffen the edge. - The top and bottom board do vibrate at bit much for my liking, so a brace is coming. - The boards are butted up using adjustable over centre clamps with sponge rubber between to stop massive vibrations. - Starting the flare at the horn exit gave us smoother results than using the full box width to start our extension from. - From memory, the 170hz drop was less nasty with our test boards on a single box. - We're using secondhand RCF lp200 drivers - I didn't expect such a gain at the bottom from my guesses in hornresp, so will be testing in a park soon to see if this is a measurement anomoly from my backyard fence or something. cheers all, Richard |
#1529 | |
![]() Rich |
#1530 | |
I was really hoping it would make little difference, because building the extension would have been much easier, but the odd asymmetric shape has kind of grown on me. We have almost finished the other pair, so soon will have plots of a matched set each side... Richard |
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
