#1511 | |
#1512 |
Hi Bart, there should be a post with hornresp model in this tread. Since you live in Belgium I can't think of another driver that come close price/performance wise.
#1513 |
To be honest Jim, I think the man deserves more credits. He is also one of few who is prepared spending a lot of time and effort in testing and measuring in favour of the community. His Keystone folding style looks very promising too and I really like the idea of the extra volume between S4 and S5 to enhance the low end. If you design correctly you can position the extra volume on the frequency you wish.
#1514 | |
StadiumHorn would have never existed without Lilmike, David and Hornresp, a FLH fiasco, and a deadline. SS15 would have never existed without screamersusa, flutes, clarinets, and a host of others input. Many of my other unpublished designs wouldn't exist without the knowledge I've been fortunate to receive from members here and other places. The reason I post some of my designs is my way of giving back. Many a small business has flourished with less than what is freely available on this forum. |
#1515 |
Even after so long my colleagues favourite ‘wrap it up in his face’ moment is my 1/4wl mistake. Somehow it has become synonym for every mistake I make
. I’m really curious about your findings of your new lay-out and hopefully you hit the jackpot in one time because I really can’t see how you can make panels from dust that is left. |
#1516 |
Hey jbell, I'm glad to see that the modification for cone volume compensation has made it from the other two bigger/lower PA TH threads over here to the SS15. Flat to 40 is something I'm also after, and if you say this gets it there, it sounds promising to me. Are you ready to post HR plots (or even inputs) comparing the two designs yet? Definitely looking forward to some measurements after you've made sawdust.
And Djim, what does the RCF L15P200AK cost in .nl/.be? Because over here in .de it's about 300€, which doesn't seem like such a good deal, considering you can get the original 3015LF for 250 or the Kappa Pro for 150.
Regards, James |
#1517 |
Hi James, you should be able to get them for 209 Euro from Thomann over there.
#1518 |
Nice to see Mr Bell is still tweaking!
I made 4 of the original SS15's with my friends Phil and Marc and we have been playing with detachable "barn doors" to see what kind of extra performance gains are possible. Phil works with large touring rigs and has been keen to make a smallish tapped horn with collapsible extensions for a while and it really does work well. We used 3 more sheets to make extensions for the 2x2 stacks, but for 4-8 db gain (curves for 1 box, 2 boxes and 2+extensions are attached), an extra 3/4 of a sheet per pox makes for a good sound to material ratio ![]() They also unclip and pack flat... It allows a pair of ss15s to hit a 45Hz corner, bumping up 40-45hz response by about 7-8db over a pair of subs with no extensions. We came to the shape after a lot of experimentation with bits of ply and measurement mics, plus deciding on 600mm maximum extension from the front. I can post sketches/plans if anyone else is keen, or just experiment yourself! FYI, forum member Art Welter did something very similar with his keystone sub, and got equally impressive gains : Horn Extender/Wave-guide for TH happy experimenting! Richard |
#1519 |
Hi r23d,
Post #1518: "...I can post sketches/plans..." Just the dimensions (size of the opening and depth of the extension) would be nice. And, what was your measurement setup? Regards,
Oliver |
#1520 |
PDC
Pretty Darn Cool |
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
