#1361 | |
Not sure if I understand how to interpret the measurements correctly. Just to clarify, are these results saying that for constant input power: With 2 speakers connected in parallel compared to a single speaker, the gain at low frequencies is +3 dB and the gain at high frequencies is approximately +1.5 dB? With 4 speakers connected in parallel compared to a single speaker, the gain at low frequencies is +6 dB and the gain at high frequencies is approximately +3 dB? If so, does this then mean for constant input voltage: With 2 speakers connected in parallel compared to a single speaker, the gain at low frequencies is +6 dB and the gain at high frequencies is approximately +3 dB? With 4 speakers connected in parallel compared to a single speaker, the gain at low frequencies is +12 dB and the gain at high frequencies is approximately +6 dB? If so, then the measured results would appear to be consistent with the predictions of the existing Hornresp multiple speakers model. Kind regards, David
www.hornresp.net |
#1362 |
Djm's plots seem to show good correlation for the +3dB for each doubling of driver @ the same power input over the frequency range 42Hz to 130Hz.
Above 130Hz the gain is clearly less than +3dB as the two comparisons show. The dual driver shows fair good correlation to beyond 250Hz, then I'm not sure how to interpret what is shown. The quad driver is clearly showing less than +3dBbeyond 130Hz and gets worse as the frequency moves towards 450Hz. Then I can't extract a sensible trend due to the rapid roll-offs. This supports my original contention that the +3dB efficiency gain is only available over a restricted frequency range. If one used full range driver/s and repeated DJM's experiment, I think that restricted frequency range to stand out even more clearly. i.e. we need to see performance upto >3kHz to SEE clearly the missing 3dB efficiency gain. The beaming of a group of HF drivers will be so severe that they become un "hifi" at high frequency. |
#1363 | |
On end correction: many of you may know this, but the term refers to the effect of the radiation impedance at the end of a tube, that changes the effective length of the tube. When calculating the fundamental resonance frequencies of a tube, one usually assumes a zero impeance in the open end. This will give a slightly higher resonance frequency than if the actual radiation impedance was used, so instead one uses the acoustical length of the tube, which is the physical length + the end correction. At low frequencies, the radiation impedance is mainly a positive reactance, a mass. A model often used for a flanged tube, is the radiation impedance of a rigid piston in an infinite wall. At long wavelengths (circumference of the tube typically smaller than half a wavelength), the acoustic mass can be calculated as Mar = 8/3pi * a * rho This mass has the same effect on the resonances of the tube as lengthening the tube by 8/3pi * a, this is the end correction. a is the radius of the tube. For an unflanged tube, the factor 8/3pi (0.85) is replaced by 0.61. This is of course a low frequency approximation, and the actual expression for the radiation impedance should be used to get good accuray over a larger frequency range. Especially for horns. This is what Hornresp does. Note also that the end correction is used for calculating resonance frequencies, not for calculating radiated power etc. Note that there is no relation to the wavelenght, other than it should be large compared to the tube radius. Only the size of the tube is important. Regards, Bjørn |
#1364 |
On a similar but unrelated note, I think most people know that bass-reflex speakers don't generate much output below the Helmholtz frequency because the pressure from the port cancels the pressure from the front of the cone. I don't think anyone would expect to gain much under-resonance output by boundary loading or grouping reflex boxes. In the passband, sure, but not below the passband.
But I think some may not realize that the Helmholtz frequency is modified by the boundary conditions of the port. There is a length adjustment made based on the area of the port. The proximity to boundaries has an effect on the Helmholtz frequency too. This is an interesting similarity to pipe-mode length correction. Another side note: Internal standing waves can make a vented cabinet exhibit both Helmholtz resonance and pipe-mode resonance. For relatively small subwoofer cabinets, this isn't usually an issue, as standing waves only occur above the passband. But full-range (mains) speakers and large subs often have a standing wave mode fall within the passband. One should be careful not to use a port long enough that it has standing wave modes in the passband. But large cabinets develop standing wave modes inside them too, much like room modes, but in the midbass to midrange band. That's an annoying problem, since acoustic insulation is not very effective at those frequencies. I have found that careful choice of port position is important, to make sure the port isn't in a pressure node. I also almost always install a sheet of insulation spanning the cross-section of the cabinet, to further attenuate these higher-frequency standing waves. These things really help mitigate response ripple. Sorry for going slightly off-topic. Seemed sort of related to mention port length correction in Helmholtz resonators. And that got me off on a tangent about internal standing waves.
#1365 | |
I made a math error and added +6 instead of +3 in one of the doublings and came out with +15 instead of +12, doh. The +12 dB (or 13 as you read it) difference in the 1986 Leap version 2.10 simulation for 1 to 15 (why 15?) cabinets is within a dB or so of an incoherent summation across the entire frequency range. You would have a better guess as to what goes on “under the hood” with Leap than I. Incoherent summation across the entire frequency range in small rooms does seems to be the case as independently measured by several DIY folks using dB meters, considering the size of the cabinets perhaps the Leap simulation is figured for small rooms rather than 1/2 space. Since you have shown interest in the 1-8 multiple BR and sealed cabinet tests, I will do them today. I'll be posting the results in a new thread, as this discussion is off topic regarding the single sheet challenge. Art |
#1366 |
Hi Art,
Post #1365: "...Since you have shown interest in the 1-8 multiple BR and sealed cabinet tests, I will do them today. I'll be posting the results in a new thread, as this discussion is off topic regarding the single sheet challenge...." This would be great. Maybe a moderator can move the whole discussion into its own thread? Regards,
Oliver |
#1367 |
![]() Chaps, if you give me a list of relevant posts and an appropriate title, I'll move them all over into a new thread. Fascinating discussion BTW, I'll be subscribing. edit: Thanks for the "heads up" Andrew.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#1368 |
Good article about sum here http://www.aes.org/tmpFiles/elib/20120113/6041.pdf
can't find "Complete Analysis of Single and Multiple Loudspeaker Enclosures" from Chris N. Strahm. Is someone can upload it? |
#1369 | |
Multiple Cabinet Combined Response Art |
#1370 | |
After catching up on a bit of sleep, I think I have managed to answer my own questions :-). Please disregard the comments I made - some of the gains I assumed, were incorrect. Attached for comparison purposes are a copy of your latest test results, together with the equivalent results predicted by Hornresp using the existing multiple speakers model. The blue trace was generated by considering a single speaker with Pmax = 4W and Xmax = 99. This means that the total constant input power to the array is 1 x 4W = 4W and that the results are not displacement limited at any frequency. A fixed 6 dB was then manually added to normalise the results, similar to yours. The green trace was generated by considering two speakers in parallel with Pmax = 2W and Xmax = 99. This means that the total constant input power to the array is 2 x 2W = 4W and that the results are not displacement limited at any frequency. A fixed 3 dB was then manually added to normalise the results, similar to yours. The red trace was generated by considering four speakers in parallel with Pmax = 1W and Xmax = 99. This means that the total constant input power to the array is 4 x 1W = 4W and that the results are not displacement limited at any frequency. The speaker used in the Hornresp simulations is not the HD15. Kind regards, David
www.hornresp.net Last edited by David McBean; 14th January 2012 at 03:54 AM. |
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
