#121 | |
In terms of the time required to put things into hornresp... it's the great equalizer. It at least gives you an apples to apples comparison, it's worth your time. What it doesn't show you is how port compression, etc... happen. Scott made an interesting comment... TH's 'bloom' where bass reflex 'wilt' at war volume.... and hornresp won't show you that. As far as this particular cabinet in the above link? Hornresp says you'll get upper 120's per cabinet 40hz on up at 63v. A 40hz 48db/oct high pass makes this design PE limited, not xmax limited from 40hz on up. I've personally run it up to about 125db with sine waves, so what I built vs. hornresp is on the money. The big difference between testing and hornresp specs are that I get a little more 40hz, and the notch at 170hz is a very narrow 2hz, 6db notch. |
#122 | |
TY for your quick response.. and of course your design. |
#123 | |
#124 |
why is 900W chosen to be "nice"?
I could just as easily suggest that "nice" equates to 900mW or 9W or some other number plucked out of the air.
regards Andrew T. |
#125 |
I think what we are gonna need here is an active DIY low cut filter. 24-48 db perhaps with the option of adding a switchable network to change the frequencies so you have a couple of choices. Perhaps 40hz and 35hz. Or a table with possible rc network vs freq so one could pick which cutoff they need. A variable pot like a crossover is nice but I strongly advise against it for reliability and unintended changing by small curious fingers.
On second thought a 12/24db 16khz low pass might be good to tack on as well for the piezo crowd. |
#126 | |
![]() I know we can have rules and contracts, but idiot-proofing is the way to go in my case. Google found this for me: http://focus.ti.com/docs/toolsw/fold...filterpro.html Good stuff! Regards, Ben |
#127 |
DIY highpass for making things idiot proof? That's what xti amps are for....
Crown XTi-1000 Stereo Power Amp Ben/Scott, I appreciate the thought, and I've even considered a 500uf passive or other type of active protection for my subs... but I just can't beat the simple setup of the xti. $329 for full '3yr no fault' warranty b-stock... delay, dsp, eq, highpass, limiter, amp... all in a password protected, front panel lock out, 17lb all digital chassis.... Runs a pair of tops and a pair of subs beautifully. And limits out WAY before 900 watts per driver is possible. Using the internal 'Y' so that there is only a single audio input, and a single volume control even keeps peoples hands off of the sub/top volume ratio, so things always sound the way you want them to sound. To top it off -- 2 channel speakon cables even prevent mis-wiring on setup.... just chain all the speakers together.. Start on the side/top, go to the 2 center clustered subs, and then on over to the other side top.... beautiful. I've been using nothing else for my school installs.... which have to be idiot proof.... Last edited by jbell; 9th September 2010 at 01:45 PM. |
#128 |
I completely agree. Next time I have a wad of cash and can start from scratch I will do so with Crown XLI or XLS! (or maybe Peavey IPR 1600 dsp?)
However, currently I am sitting on a bunch of heavy old iron. I have a variety of soldering irons and tools and I like ScreamerUSA's idea. But maybe I ought to grow up and sell the old iron... Regards, Ben P.S. over here it's €525 - so approx a very evil 666 US Dollars http://www.thomann.de/de/crown_xti_1000.htm Last edited by salzburgsoundsystem; 9th September 2010 at 01:45 PM. |
#129 |
#130 | |
12db/oct... I wouldn't... nope, no way. 24db/oct minimum if you are going to set it at 40hz on this sub. And the yammy filter can be EITHER low cut or low pass... the xti allows you to HP butterworth 40hz@48db/oct, LP 95hz@24db/oct linkwitz riley, and then also use 24db/oct HP for your tops if you choose to run tops on channel 1, and subs on channel 2. For a loud cheap DJ proof setup that fits in a corolla... I haven't found a setup that beats a pair of the half sheet beta12a tops, a pair of the single sheet subs and an xti. |
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
| Page generated in 0.11323 seconds (71.61% PHP - 28.39% MySQL) with 11 queries |
