Old 28th December 2011, 01:17 AM   #1191
Originally Posted by screamersusa View Post
WOW! Now that's a cool table.. I wish I was so neat and organized
Perhaps adding external dimensions and if they are designed with truck pack friendly wheels
might be usefull. I did have to keep in line with standard truck pack sizes. Two Meyer Up-1 fit perfectly on top of the cab so most don't realize I don't have matching meyer subs. That was another issue I had to deal with.
Thanks, I was having a rough day till I saw the chart..
Ahhh what is a pyrosub? I hunted through the posts already.
4Pyros built his 3015LF SS15 cabinets from 3/4" rather than 1/2" and added some bracing.
Should be the same as the standard SS15 as far as frequency response and sensitivity.
The chart pretty much reinforces Hoffman's Iron Law.
Old 28th December 2011, 01:23 AM   #1192
Thanks for the clarification.. That's what I was planning to do as well for hi hat (pole) mounting. Although I was debating 1/2 inch for the insides and adding about a 1/2 inch width for the bracing.
Old 28th December 2011, 01:26 AM   #1193
DJM what about putting the "gold" standard TH-115 or USC-1 on the chart as a reference, or would that be in bad taste?
Old 28th December 2011, 01:44 AM   #1194
jbell is offline jbell  United States
have a heart scott... I already feel inadequate....
Old 28th December 2011, 01:47 AM   #1195
Djim is offline Djim  Netherlands
I would love to enter true data for Danley's TH's into my table. But somehow I doubt Tom wants 'us' to reverse engineer his TH's to check his specs on accuracy.
Talking of which, your Furybox definitely needs its own thread for some precise analyses because I'm not sure the data is accurate enough.
Old 28th December 2011, 02:06 AM   #1196
Xoc1’s TH18-2 has the same physical dimensions as the DSL TH-115 or TH-118, and similar frequency response as the TH-118, which uses the BC18SW115-4.
The DSL TH-118 is rated at about 105 dB one watt one meter (spec sheet uses 28.3 volt at 10 meters).
My slightly larger volume Keystone BC18SW115-4 loaded tapped horn actually measures about 98 dB sensitivity in the upper range (same as a JBL-SRX 728, a slightly larger 2x18"), about the same as Xoc1’s TH18-2 Hornresp sims.
I have communicated about the disparity with Tom Danley, although he agreed that the disparity sounds too large, he stands by the spec sheet figures. He did share the actual plans of the TH-115 with me, Xoc1’s TH18-2 are nearly identical other than one small detail that Tom does not believe would make much difference in sensitivity.
Josh Ricci has tested a DSL DTS-10, his test results show a much lesser sensitivity than Danley’s spec sheet, very much in line with the disparity between Xoc1’s TH18-2 or my Keystone compared to the DSL TH-118.
My tests showed the TH increased the sensitivity of the BC18SW115-4 by 6 dB over a slightly smaller BR cabinet with the same low corner.
Six dB is a big deal, another 6 or 7dB on top of that with the same FR and cabinet volume (and fold pattern) is IMHO, impossible.
Art Welter
Old 28th December 2011, 02:35 AM   #1197
The 18SW115-4Ohm version also does peak 105dB in the Xoc1-TH18-2 with 2,83V but that is peak (95Hz) and not average and with 2,4W/1m.
Old 28th December 2011, 02:42 AM   #1198
Starts with post #584 of this thread. It is not a true SS15 it takes about a sheet and a half.
Old 28th December 2011, 02:57 AM   #1199
I'd like to revisit the fury through building another one but time has not been my friend for a few years now. I was under the gun at the time and expected you guys to surpass it.
The CTH-15 was the best sounding and loudest box I came up with but there were so many small parts that it was not practical to build. That one was hitting 103-104 so Danleys spec may be quite right.
We learned a lot building these, with quite satisfying results, within our meager budgets.
On the ss15.. JBell seems to have optimized it pretty darn good. The only thing I notice is there may be a cheezy useful mod for it.
If you decrease s5 you get more low end extension at the cost of a few db...so:
Hows about a removable wedgie? Heavy duty velcro on the bottom and felt or carpet on the sides for a snug fit. You could add another box and toss the wedgies in to drop the low end 5hz or more. The added impact to the audiences central nervous system should do the trick without having to push the system any harder.. Thoughts?
Old 28th December 2011, 03:07 AM   #1200
It looks like a couple of different size wedgies would give you options. Dance music use a smaller one for more ummph, Theater/corporate presentation use a bigger one for more rumble. You could even have hand holes to carry them and pull them out with right on the front. Or leave a compromise size glued in. Same cabinet, different options for different events.
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
