#1101 | |
To give some idea of this club: Then: 6 CV 15" 3-ways for tops, two CV 18" FL horns for bass Now: Rented equipment - 4 18" "scoops" (loaded with BNC drivers) for bass, tops unknown - some DIY design from Trinidad loaded with a 15", a 10" and a compression horn. A WT3 test on the scoops suggests that they're turned to 35 Hz. What they're currently considering: Four of the previously-mentioned EV 18" subs for bass, and rebuilding the previously-mentioned CV full range boxes. I suspect that the EV 18" subs may be a step down from what they're currently using .I'll mention your ideas to him. |
#1102 |
Tell him to build (2) Berta's with the mouth extensions (Levan) Insane Bass from them!
Now This is a sub! Bertha...W bin Personally I don't think the ss15's will be enough for a club considering the tuning...Many songs will have content below the tuning and can kill the drivers pretty easily (without proper monitoring of clipping etc) Last edited by m R g S r; 12th October 2011 at 05:42 PM. |
#1103 |
How many litres for how many dB SPL?
How long is the horn? To what frequency does it hold flat? |
#1104 | |
Yes, dnb, etc has content below 40hz that may be needed in a club. However the first thing that is requirement, is that the brother needs to be convinced of the advantages of TH. Only when that is accomplished can he start considering what low cutoff and spl targets he wants to achieve. |
#1105 |
Ohh I kno about the high pass on it. But even with it set up, on a heavy bass track with a DJ pushing the system for more output, he will probably drive the amps to clipping not paying attention etc etc. That's what I was referring to. I guess I was saying it from
More of a headroom perspective. It's better to have more headroom and not worry. |
#1106 |
ahh... got it... 4015lf and brickwall limiters help with an aggressive dj for an ss15.
The best defense (even makes things kid proof) is an XTI amp with everything in one chassis PASSWORD PROTECTED. |
#1107 |
Hi there, Brian Steele i'm from TRINIDAD the DIY top from Trinidad loaded with a 15", a 10" and a compression horn.Is a copy of the EAW KF850z top
#1108 | |
One of my brothers indicated that it lacked midrange, but that may be due to "boomt-iss" tuning by the DJ (if you're really a trini, you'd know that term, LOL. The non-trinis here should be able to figure it out ). I wasn't in the club long enough to have a look at how they were being driven.BTW, sometimes copying (or rebuilding) a commercial system may raise some interesting issues - see my attempts at rebuilding the CV tops here - So, my brother brought over 4 blown Cerwin-Vega Pro Stax PSX-153 speakers... - Techtalk Speaker Building, Audio, Video, and Electronics Customer Discussion Forum From Parts-Express.com |
#1109 | |
I've found a few places to buy these, but I can't find any T/S or other detailed specs on these. What data did you use to simulate it? Or where can the data be found? Is it official or measured? At a woofer this price, it's probably best to invest in a woofer tester to make sure the parameters don't deviate too much. But at 1/4 of the current price of the 3015 (50% price hike - ouch!) that's definitely in the budget.
Regards, James |
#1110 |
Candidates for the Darwin Award should not read this author. |
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
