#1091 | |
A TH eats their lunch for praise band.... Not much of an exact comparison, and I know it's apples and oranges. A 45hz TH vs a bagend elf... yea, not a good comparison. This is one of those things that you actually have to do it yourself to believe it, trying to convince someone usually doesn't work.... That's where the singlesheet thing works and makes believers. Buy a $100 kappa pro 15lf2, a $30 sheet of ply and a tube of pl. Get out the deck screws and make something ugly... and then crank it up. The sound sells itself. Then once convinced, you can then figure out your extension and spl goals, and choose the appropriate design. (put it in the night club and change the direction of the speaker, and watch the faces as the bass 'moves'..... that's priceless) Surely your brother trusts you enough to do an ugly box just to see? Last edited by jbell; 12th October 2011 at 03:43 AM. |
#1092 |
Candidates for the Darwin Award should not read this author. |
#1093 |
djk howmany liters is that?
Regards, Dan |
#1094 |
should the spacing be double for the taps??? The numbers are for one driver not two...
Regards, Dan |
#1095 | |
I'm pretty sure the Dynacord Cobra's use the same driver that is in the MTL boxes....I've heard the Dynacords on numerous occasions...not bad at all! Last edited by m R g S r; 12th October 2011 at 04:48 AM. |
#1096 | |
. Pity about the current cost of the Kappalite though. The 18" TH design does look interesting though, particularly with its 35 Hz extension. No actual measurements posted yet, unfortunately. I'd tell you he was impressed with the little DFD'd POC#2 with the 12" Dayton pro audio driver. It was able to keep up quite easily with one of the CV 15" 3-ways I'm fixing for him. Actually had to turn the gain down a notch. However, when thinking of dropping major $$ on a club system, it is an uphill battle to convince them to consider DIY instead, particularly when some of the "DIY" examples here have been so bad... Last edited by Brian Steele; 12th October 2011 at 05:22 AM. |
#1097 | |
How about those comparitive measurements of your stuff - earn the right to talk some smack... ![]() ![]() :
Regards, Dan |
#1098 |
"The numbers are for one driver not two... "
I was lazy, I just created one driver with the same parameters as two. I also ran it in Hornresp with two drivers, but with S3=3400 and S4=3600. It's about 700L (about the size of a LAB 12), and 105dB/2.83V/35hz. You could build it as a pair of singles and stack them. If you can make it bigger than a LAB 12 you can pick up another 3dB:
#1099 |
This one is much smaller (410L or two 205L), 3dB down around 37hz, 105dB around 50hz.
{ a1 = 1000e-4; |Area at throat (cm^2) a2 = 1700e-4; |Area at rear of driver (cm^2) a3 = 2200e-4; |Area at front of driver (cm^2) a4 = 2400e-4; |Area at mouth (cm^2) l1 = 18e-2; |Distance from throat to rear of driver (cm) l2 = 175e-2; |Line distance from rear of driver to front of driver (cm) l3 = 20e-2; |Distance from front of driver to mouth (cm) Sd=1745cm2 fs=42Hz Qes=0.54 Qms=6.73 Vas=232L Re=2.52ohm Le=2.49mH I like the 4015, they were only about $140 each the last time I bought a dozen.
Candidates for the Darwin Award should not read this author. Last edited by djk; 12th October 2011 at 05:38 AM. |
#1100 | |
a pair of powered qsc K12's over a quad of ss15's with a single crown or qsc amp w/crossover would run $2500-$3000. I know my brother did a bar with all EV... !@#$ was that place loud. To be perfectly honest, it sucked. It was so loud everywhere, that you couldn't tell what the sound system sounded like. The TH's that give you some bass directionality, coupled with a reasonable top with good pattern allows you to have club level in one place, and still be able to talk elsewhere... THAT is the key to a club system. |
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
