Single sheet TH challenge - Page 100 - diyAudio
Old 20th April 2011, 06:11 PM   #991
Djim is offline Djim  Netherlands
Same as usual MrGsR:
Eminence 3015lf, 18Sound 14W700, JBL 265H-1, P.Audio C15-600EL, RCF L15-200AK....
But I think you need an extra piece of wood for this. The idea behind the design is extended LF (at cost of 3dB max) and it should match with an original SS15 and both can be powered with a standard 900watt/4Ohm amp. The total response of the two together should equalize the dips and peaks with no fase issues.
Old 21st April 2011, 01:15 AM   #992
Just took a look at the driver mentioned in post #964 which is a 12" woofer sold by MCM it looks to be an intersting drive. However I saw Dan's comments about T/S data and MCM drivers. Has anybody bought and measured one of these woofer and are they close to the stated specs? MCM # 55-2982. thanks and best regards Moray James.
moray james
Old 21st April 2011, 05:29 AM   #993
FlipC is offline FlipC  United States
Thats not from a single sheet ...
Old 21st April 2011, 08:00 AM   #994
ok im trying to get to grips with Horn resp using the ss15 but ill be honest, i dont have a clue where to start.
I tried typing the parameters that i found in post #54 but i dont know what other setting i need to adjust because its not as straight forward as copying the numbers.
Im trying to find out if the
http://www.eighteensound.it/renderPdf.aspx?pid=283
18sound 15NLW9400
will work in the ss15. I have a couple of these winging there way to me and im really hoping they could be a high power upgrade over the 3015LF.
They are recommended as such for the t48 so if they dont work in the SS15 then i will stick them in a couple of t48.
Of course i would rather be able to model the speakers myself...
Old 21st April 2011, 01:10 PM   #995
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
..18sound 15NLW9400..Of course i would rather be able to model the speakers myself...
Hi, Here is a HR template to start with:
b
Old 21st April 2011, 04:12 PM   #996
Nope, extra pathlength means extra internal wood...
Old 21st April 2011, 06:42 PM   #997
tb46 is offline tb46  United States
Default SS15: 3015LF_v_15NLW9400
Hi Dave NonZero,
Here is the 18Sound 15NLW9400 stuffed into the Hornresp input from the SS15(3015LF). Maybe you can optimize the design from there.
Oliver
Old 22nd April 2011, 10:31 AM   #998
Originally Posted by jbell View Post
Fortunately several drivers model very well in the ss15 cabinet.
The kappa pro 15LF-2 comes to mind. Eminence Kappa Pro-15LF-2 15" Cast Frame Driver
Yea it's 25lbs instead of 10, but it's within a db of a 3015lf in output, and half the price.
...while exceeding xmax by 3mm, no? I believe you have to reduce input power to 200W to bring the displacement to the rated/published xmax (which in turn brings down SPL quite a bit...).
If all of the sub-$200 3015LF's go bye-bye, I think the next best bet (response wise) would be the RCF L15P200AK 15" Woofer at $259/ea or even better, the 4 ohm variant -- IF you can find it in the states.
Old 22nd April 2011, 01:46 PM   #999
jbell is offline jbell  United States
run the hornresp for the kappa pro 15lf... it runs lower xmax while producing within a db of the same sound. It stays within xmax at 63v
Old 22nd April 2011, 01:47 PM   #1000
I just wanted to be the 1000th post.... never thought this thread would go this far. Thanks all.
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Renovation Challenge ZirconiumZephyr Multi-Way 16 1st September 2009 08:38 AM
Design Challenge #1 kgillies Subwoofers 12 13th June 2007 03:20 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
Copyright 1999-2017 diyAudio
