Wharfedale W-25 RS
Wharfedale W-25 RS
Old 23rd July 2010, 02:05 PM   #1
Rockaway is offline Rockaway  United States
Default Wharfedale W-25 RS
I posted a similar inquiry on another board but I have a new angle on this problem. I have two Wharfedale w-15 Rs drivers that I use for LF off an electronic crossover. They are currently on open baffles. One of them rattles
badly when driven with deep bass. When I depress it there is no indication of
VC rub. In fact, it seems like it has a large gap. I am now speculating that the cloth surrounds which are solid, may be less sealed than I suspected. I can blow through them using the Troels Gravesen straw test. Am I deluding myself
that this driver is not simply blown?
Thanks in advance for any suggestions.
Old 23rd July 2010, 02:06 PM   #2
I meant w-15 RS
Old 28th September 2011, 03:33 AM   #3
klipschorn is offline klipschorn  United States
klipschorn's Avatar
Send a message via Yahoo to klipschorn
Smile W15RS in open baffle.
I realize a year has passed and hopefully you found and fixed the problem. Yours recalled a similar problem I read here about an hour ago. Turned out to be a loose dust cap. You might also look at the spider as part of it may have come loose.
A note worthy of mention. If you're using these in/on an open baffle, the annulus, surrounds, not being air tight would make no difference unless they're "puckering" during long excursions. If you haven't damaged these speakers in such a baffle by now is somewhat of a miracle unless you don't "get on" them. That roll surround won't hold without proper baffle/cabinmet loading. Most speakers used in open baffles usually have stiff suspensions and as a result, won't do well at low frequencies below 50-60 hz.
Old 5th May 2012, 05:23 AM   #4
Just saw your comment. I have been off this board for a while. I did mend the dust caps which had become unglued. As for the surrounds, I suspect you're right and will look for damage. I use these crossed below 150hz and the excursion tends to be barely visible with the music I listen to however I some electronic music will drive them to dangerous threshholds.
Thanks for the warning.
Jason
Old 6th May 2012, 05:24 PM   #5
devilsindetails is offline devilsindetails  Canada
devilsindetails's Avatar
Just a guess on my part...are you using any frequency equalization with your set-up? Does the buzz exhibit itself when running tone controls flat or bypassed?
I've noticed with a lot of electronica music that there is a certain amount of LF wave complexity that the older drivers with more compliant surrounds seem overwhelmed to handle.
Looking at your OBs I am also thinking they may not quite be wide enough for the size of the two large drivers you are utilizing...but difficult to tell without any dimensions and measurements.
"A problem left to itself dries up or goes rotten. But fertilize a problem with a solution--you'll hatch out dozens." (N.F.Simpson)
Old 6th May 2012, 08:31 PM   #6
This puppy's got wings. Not installed yet. They are about 6" per side. They fold back however for casual listening.Total width is about 30" .
Height is 36" if memory serves me. Electronic music souns best on sealed enclosure systems. IMHO
-j
Wharfedale W-25 RSHide this!Advertise here!
cheap (230v 50hz) 160va 25+25 tranny on ebay guitar_joe Swap Meet 0 24th November 2007 11:53 PM
cabinets for Wharfedale 10 RS DD Golden Pat Lindsay Multi-Way 6 19th January 2007 08:48 AM
MCM sale: Tenma autoranging RS-232 DMM, $25 Taligent Parts 13 29th August 2005 02:13 AM
RS Labs RS-A1 Tonearm New Unused Boxed mozfet Swap Meet 4 6th September 2004 11:51 PM
10inch BRONZE/RS/DD Wharfedale full range drivers SkinnyBoy Multi-Way 0 12th February 2004 05:09 AM
Copyright ©1999-2017 diyAudio
