Old 22nd July 2010, 01:21 AM   #1
katana2112's Avatar
Default I have a couple of these WT-644s
I have 2 1cuft boxes and 2 BFM Autotubas(all empty), would these be any good in either? Any thoughts as to what kind of woofer/subwoofer I can build? Im a woodworking novice but I have all the tools.....Any feedback appreciated.
http://www.tb-speaker.com/detail/1208_03/wt-644f.htm
Aggressively Passive
Last edited by katana2112; 22nd July 2010 at 01:26 AM. Reason: need to add attachment
Old 24th July 2010, 06:25 AM   #2
katana2112's Avatar
Bump
Old 24th July 2010, 09:43 AM   #3
chris661's Avatar
Perhaps modelling them in winISD would be a good idea?
I expect 1 cuft for a driver like that would be too small, though adding a Linkwitz Transform would get more bass out (at the expense of max.SPL - still, they have enough excursion to go pretty low).
If you have the stuff already, why not try it, experiment with stuffing and things like that?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 24th July 2010, 10:16 AM   #4
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by chris661 View Post
..I expect 1 cuft for a driver like that would be too small, though adding a Linkwitz Transform would get more bass out (at the expense of max.SPL - still, they have enough excursion to go pretty low)..
Agree, 1 cu.ft would be good for use in a car ,f-3dB ~ not below 60 Hz but this driver is IMO very well suited for T-TQWT applications :
b
Old 24th July 2010, 03:29 PM   #5
chris661's Avatar
Ah yes, Hornresp. I still find it amazing that you can (seemingly endlessly) roll out various plans for various drivers, Bjorno. I got a graph out of it. Once.
Anyway, I seem to remember that Logitech uses this woofer (maybe a SVC version) in their Z5500 set-up.
Old 25th July 2010, 01:49 AM   #6
katana2112's Avatar
Default Hornresp
I like the look of the horn on the left I just havent had enought time to figure out the workings of hornresp yet.....
Modifying Preamp Frequency Response - Eden WT-800 to WT-400 duff2 Instruments and Amps 3 2nd February 2009 03:46 AM
WT Visaton AL170 gaborbela Swap Meet 3 3rd May 2008 01:24 PM
cap couple or direct couple class A SE amp? AudioGeek Solid State 7 7th May 2005 06:16 PM
WT Reference Plinth Question. MIDUN Analogue Source 0 23rd April 2004 09:31 PM
Page generated in 0.08010 seconds (72.75% PHP - 27.25% MySQL) with 11 queries
