Help needed choosing a design for live sound - Page 3 - diyAudio
Old 22nd July 2010, 10:00 PM   #21
davygrvy's Avatar
There's a large jump in efficiency when you use many (small) speakers together. Here's an example of tapped horns (from Tom Danley)
many == good
Think out of the box
Old 23rd July 2010, 02:52 PM   #22
BP1Fanatic's Avatar
Nice!!!
Old 23rd July 2010, 06:48 PM   #23
davygrvy's Avatar
I hope Pyroibw considers jbell's small cubes. Although the cost is a bit higher due to the need for more drivers, the end result is a more configurable system and is better on the back and will go louder compared to fewer larger cabinets.
Old 1st December 2010, 05:24 AM   #24
on the outer cabs, the amount of delay is calculated from the outer distance the center stack?
Old 1st December 2010, 12:31 PM   #25
jbell is offline jbell  United States
umm... I'm not sure how to 'calculate' the amount of delay. Based on the edge to edge spacing of the mouths -- it's different. There is a maximum spacing edge to edge for subs to 'combine', and It is directly related to the upper frequency you want your subs to produce, however a good rule of thumb is about 4' or less. (the wider the spacing the more delay needed, however it will be somewhere between 1 and 4 milliseconds.)
What I did is use a spl meter and sine wave. Start the sinewave and measure straight on. Then move the spl meter to 45degree off axis. Start dialing in delay until the 45 degree off axis and straight on are about equal. As you add delay, at some point you'll start to hear a 'hollow' or weird kind of sound head on -- that's what tells you, you delayed too far.
Old 2nd December 2010, 04:08 PM   #26
Top Shelf's Avatar
Its about 1.1 milliseconds per foot.
JEREMY M_________________________________
I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ?
Old 2nd December 2010, 05:00 PM   #27
yea... I got that.
TopShelf Can you fill in this word problem?
edge to edge spacing = 2' in a 4 box group.
45 degree off axis is -6db down with no delay.
how many ms delay to make 45 degree spl = 0 degree spl at 40hz?
(hint, I know the answer for MY BOX only.... because I measured it. anyone else's box, no idea...)
just knowing the speed of sound doesn't help me 'calculate' the outer box delay.
anyone got any formula's that might help?
Old 2nd December 2010, 05:30 PM   #28
Top Shelf's Avatar
Pythagorean theroum should Work. Depending on how far away the measurment is taken from test or listening point in front of the mmiddle or(reference) box.
Old 2nd December 2010, 06:12 PM   #29
ok, lets see if a2 + b2 =c2 comes up to the right answer.
30 feet measurement distance... measured in arc so its 30' head on, and 30' at 45degree off axis, measured from the center of the 4 box cluster. you have all of the numbers... lets see if you come up with what I know works.
btw, how does -6db relate to pythagorean theorum?
(bonus points for showing your work)
Old 4th December 2010, 03:33 PM   #30
Top Shelf's Avatar
Ill get back tomorrow really busy now.
Live sound monitor speakers (band) gain wire Full Range 14 11th March 2010 07:45 AM
How to achieve the LIVE sound? Like you ARE THERE? rjp366 Multi-Way 52 12th October 2009 04:39 PM
LM3886 PA/Live Sound designs? takodabut Chip Amps 2 21st December 2006 05:42 PM
Live sound frequency/power split Pbassred Solid State 2 4th March 2004 03:19 PM
Sound Blaster Live Processor audioaction Parts 7 29th July 2003 08:18 AM
Copyright 1999-2017 diyAudio
