Am I crazy?
Am I crazy?
Old 19th July 2010, 06:25 AM   #1
TundraLTD is offline TundraLTD  United States
TundraLTD's Avatar
Default Am I crazy?
Would there be ANY advantage to adding an impedance equalizer to a TH [or any other sub] design for instance? to keep impedance peaks under control, I haven't seen them used in subwoofers
Old 19th July 2010, 08:16 PM   #2
chris661 is offline chris661  United Kingdom
chris661's Avatar
I think I know why.
99% of the time, the subwoofer in a system is driven by a solid state amplifier. A decent one of those simply won't care about wierd impedance curves. So there really is no need.
My work: www.grimshawaudio.com
Old 19th July 2010, 10:14 PM   #3
dave w p is offline dave w p  England
There's a good chance it would end up sounding worse. The thing that keeps impedance under control is the amp, or rather the damping factor, and like chris says anomalies in impedance curves are no problem to a decent amp.
I'd steer well clear.
The HIFI site
Old 19th July 2010, 11:40 PM   #4
soho54 is offline soho54  United States
Not in a horn. The horn over-rides the drivers normal loading with it's own acoustic loading.
Old 22nd July 2010, 01:49 AM   #5
davygrvy is offline davygrvy  United States
davygrvy's Avatar
What's an impedance equalizer used for? I'd be concerned not on the peaks, but the dips along with the phase angle as it determines how deeply you'll be abusing the amp. This is a good read: Stereophile: Heavy Load: How Loudspeakers Torture Amplifiers
Think out of the box
Old 22nd July 2010, 07:17 AM   #6
They are used by some in passive xovers/EQ to flatten(straight line) a driver(s) impedance over a certain range to help with xover integration/overlap between drivers.
Old 22nd July 2010, 07:42 AM   #7
chris661's Avatar
Fair enough, but you'd not need that for a subwoofer crossed over before the amplifier (the cost of crossing them post-amp would be horrific).
Chris
Old 22nd July 2010, 07:53 PM   #8
davygrvy's Avatar
There's a pink elephant in this room, but no one has brought him up directly.
The performance you can achieve with a DSP based line level x-over far exceeds lossy passive components that disrupt damping factor and efficiency. Not only that, but the cost of doing it at speaker level [as chris says] might even be half the cost of a DBX DriveRackPA+ that has 1000x the control for tweaking and driver protection.
It's huge and pink!
Please don't screw-up your sub with passive x-over junk.
Old 23rd July 2010, 03:09 AM   #9
I never told him to use it. I just answered some questions.
Old 23rd July 2010, 11:00 PM   #10
head_unit is offline head_unit  United States
I don't know that the original OP was intending to use passive crossovers on his sub. I hope not, since they just don't work.
I assume he was asking more "What's the use?" Presumably, the use would be to flatten the phase angle and present an easier load to the amplifier.
That is what Richard Small worked on at KEF at one point-conjugate networks to flatten the speakers' impedance and "make your amplifier more powerful" as the much-ridiculed marketing hype put it.
That assertion was probably true for many amps, especially lower priced designs. If you have some huge built-like-a-tank smartly designed amp, it may not matter.
But the missing piece of the puzzle is: do the fixed-impedance passive components really compensate well, when the driver impedance is changing with motion and self-heating due to input power?
In any case, conjugates at bass frequencies would be big and heavy and EXPENSIVE I should think, due to the large component sizes and need for high voltage handling. Probably cheaper to buy a bigger amp!
Am I crazy?Hide this!Advertise here!
Crossover crazy Dryseals Multi-Way 3 26th September 2006 10:52 AM
I must be crazy, Hello from Colorado Harlan Introductions 3 15th February 2004 02:02 PM
LM3886 gone crazy!! soundNERD Chip Amps 1 24th October 2003 02:16 AM
Is this crazy? dc Multi-Way 25 20th October 2002 07:29 PM
Copyright ©1999-2017 diyAudio
