Once again, I come searching for help... this basically means that I'm thankful of every single idea and suggestion that comes out
Originally, I had the idea of building a 3-way loudspeaker system that would do me the "impossible" 20Hz-20KHz range. This would give me humongous loudspeakers, and even if I knew myself able to sacrifice some space on the living room for those monsters, my girl didn't agree with me much. Therefore, I went straight ahead to a different approach: a pair of 2 way small bookshelf speakers (on the run, using a sealed enclosure, egg shaped) + one (sub)woofer for the frequencies below 100Hz. I must confess I'm a huge fan of what's achieved by a backloaded transmission line enclosure, and paying attention to the WAF I ended up thinking on something similar to the "perfectionist audio subwoofer": a huge wooden box that would occupy the space below the flatscreen. On this idea, I had huge help from pkitt, that made me all the simulations for a TL using Seas L26 woofer, reaching the desired 20Hz. For that I'm extremely grateful! However, thinking on it as something to endure a longer time, I started thinking: why not using a better (although more expensive) woofer alredy? Is the Seas W26 001 any better? What about the L26ROY subwoofer driver? Conclusion: The idea is still the same: a mighty woofer on a TL enclosure that would reach the 20Hz with high bass precision, knowing that it would be cut (1st order) at about 100Hz. Help on which woofer to select, and later on the TL drawing is what I'm asking for. Thank you in advance! |
#2 |
I guess you already know the answer to your questions. You have the simulations for the Seal L26 woofer. Now just do the same with the W26 001 and the L26ROY drivers. Comparing the results - freq response, group delay, impedance curves, impulse response, enclosure volume etc should give you the answer for the best choice.
http://www.audioheuristics.org/measu...fer%20test.htm I just found this, the L26 woofer seems a solid choice! Last edited by rhapsodee; 17th July 2010 at 07:50 PM. |
#3 |
I'll be interested in your build and the results. I've been considering the L26 also, albeit in a 40L box with Seas' passive radiator.
Any technology sufficiently advanced is indistinguishable from magic |
#4 | |
Anyway, it would be interesting to know which woofer is best suited for a TL box, price and size off the calculations. Who knows, maybe the cheapest (L26RFX/P) will win |
#5 | |
I built an open end TL subwoofer with two 6" Morel woofers. It certainly had impressive extension, though it was actually rather a large box! Quite a "fast" sound, though perhaps not as much as sealed. If you have one source playing to 20Hz be prepared to use EQ or a lot of experimentation with room placement. The alternative is to use 3-4 subwoofers around the room to achieve a flat response at the listening position. Good luck with it, it should be an impressive unit! You might be surprised how low it plays in room, my TL wasn't flat to 20Hz on sims but pretty much was in room |
| Help a new guy with TL enclosure | thematrimix | Full Range | 60 | 8th December 2011 02:25 PM |
| TL Enclosure Design | schmeet | Subwoofers | 11 | 3rd April 2008 01:21 PM |
| Best enclosure for SQ? TL? | defwing | Multi-Way | 1 | 4th February 2008 03:10 PM |
| New woofer for TL Sub? | BAM | Subwoofers | 0 | 9th January 2005 02:51 AM |
| TL Enclosure question | CH2 | Multi-Way | 0 | 23rd April 2004 03:21 AM |
| Page generated in 0.09333 seconds (76.60% PHP - 23.40% MySQL) with 10 queries |
