Opinions needed on Tapped Horn drivers
Old 2nd August 2010, 03:34 AM   #11
zobsky is offline zobsky  India
zobsky's Avatar
I got fed up of pondering over the options so this afternoon, I cobbled up 90 % of an enclosure. We'll find out soon enough whether this works or not. Hornresp indicates that this design is fairly forgiving (in theory) and will work with either the PYM 1298 or the shiva 12 (and possibly the dayton 12 DVC or any other "typical" 12" DVC sub).
Strangely, the build so far only took 4 hours (a personal record of sorts). As to how it sounds, we'll find out after I brace the cabinet. I believe that T-TQWT need some stuffing in the first couple of segments.
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 2nd August 2010, 03:36 AM   #12
zobsky's Avatar
And the plan. Please note that there is a typo in the distance of driver from the end, .. it should be 230 mm , not 200 mm. Also, it's not apparant from the plans , but interior panels are 12" (305 mm) , .. and I had to rebate out a little of the sides in order to be able to get the 12" driver to fit (see previous pic)
Opinions needed on Tapped Horn driversHide this!Advertise here!
Adire Koda 8 tapped horn , advice needed 316a Subwoofers 7 17th June 2010 04:12 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 06:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 01:51 AM
tapped horn isobaric drivers bubblersound Subwoofers 4 18th June 2009 03:42 AM
Crossover point for Scan-Speak Drivers - Opinions needed ShinOBIWAN Multi-Way 50 27th March 2005 02:25 PM
