Old 15th July 2010, 05:58 PM   #1
zobsky is offline zobsky  India
zobsky's Avatar
Default Opinions needed on Tapped Horn drivers
This is for home theater purposes, so the required response would be between 20 Hz and 80 - 100 Hz.
I have a bunch of drivers in my stash that could work, I'll post my horn resp sims later in the evening, but from simulations with a low frequency knee of between 20 - 25 Hz,
My DVC 4 ohm / 20 Hz / 15 mm xmax Adire shiva mk IV 12 seems to work in a negative tapered TH (T-TQWT), relatively compact at about 100 liters
http://stereointegrity.com/Files/OldAdireDrivers.pdf
My high-efficiency 8 ohm / 45 Hz FS / 3 mm Xmax PYM-1298 , ..clones of Eminence Kappa 12A seem to work in either a larger TH or more compact T-TQWT
Eminence Kappa-12A 12" Driver 8 Ohm | Parts-Express.com
I'm more interested in low freq. response than ultimate SPL, .. but I'm concerned about running out of xmax.
Any suggestions, opinions., etc .. ? As I said, I'll post sims later when I get back home.
"Any fool can know. The point is to understand" - Albert Einstein
Old 15th July 2010, 06:15 PM   #2
tb46 is offline tb46  United States
Default Jbl gto1214
You may have seen the thread by Petter Persson:
http://www.diyaudio.com/forums/subwo...n-2x12-th.html
This driver modells well in Hornresp, and you can find it for under $100.--. Maybe a dual driver super SPUD on the cheap?
Oliver
Old 16th July 2010, 01:56 AM   #3
zobsky's Avatar
Here's a sample sim for the shiva . Opinions on potential real - life performance and excursion control?
Old 18th July 2010, 04:43 AM   #4
davygrvy's Avatar
looks good, make some sawdust.
I have a 15" Adire Tumult (34mm Xmax) just waiting for me to build a TH cab for it. I can model 'till the cows come home, or just do it and use it. And what you have looks great; go for it.
Watch 21 hertz for excursion limit and set your loudspeaker processor to hard limit the input voltage to the amp to prevent from hitting it. What's interesting with TH cabs, is excursion limit is in the passband rather than below for other types. With 2V shown as giving 97 SPL in 1/2 space, that should totally kill
Think out of the box
Old 24th July 2010, 06:45 PM   #5
zobsky's Avatar
Tweaked the design by offsetting the driver , .. the benefit is mostly in reducing the group delay. Note that the frequency of max. excursion has moved to around 30 Hz. The 80 Hz peak can probably be addressed by stuffing the wider part of the line.
Old 24th July 2010, 09:20 PM   #6
Default T-TQWT v. BR
Hi zobsky,
Not trying to be contrary, but when I compare (@ 2pi/2V) this T-TQWT enclosure to a BR of same total net volume the BR seems to be the superior solution. Better frequency response, group delay, impulse response and excursion control. Not to talk about the ease of construction. So why go through the exercise?
Oliver
Old 24th July 2010, 09:39 PM   #7
Default Inputs for #6
Here are the input screens for Post #6.
Oliver
Old 24th July 2010, 10:50 PM   #8
zobsky's Avatar
Originally Posted by tb46 View Post
Hi zobsky,
No good reason Seriously though, TLs sound subjectively better to me than reflexes, and my last expt with a T-TQWT a few years back was encouraging enough, so I'd like to try this experiment again. For a number of years, I had the shiva in a 145 liter EBS tuned enclosure tuned to below 20 Hz and it was great for home theater purposes as long as the main speakers weren't super efficient. When I went hi-efficiency, I had to dismantle that experiment
Just for kicks, here's a 20 Hz TL subwoofer set up of mine from even longer ago, paired with vintage magneplanars , .. eventually ended up being even taller. Sadly had to be dismantled due to several major room suckouts in that room of the house I was living in. Shorty after that, I gave up trying to get any form of decent sound from that room.
looking for BIG sonotube transmission line advice
Old 25th July 2010, 12:29 AM   #9
Hi zobsky,
I think I get it, have you considered a large TH for the Shiva?
Oliver
Old 25th July 2010, 01:25 AM   #10
zobsky's Avatar
Hi zobsky,
Yes, I did but the point of this T-TQWT was to desgin a smaller tapped pipe at the expense of some efficiency loss. In any case, I don't think the shiva is the optimal driver for a tapped horn, ..though it can be made to work.
Adire Koda 8 tapped horn , advice needed 316a Subwoofers 7 17th June 2010 03:12 AM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
tapped horn isobaric drivers bubblersound Subwoofers 4 18th June 2009 02:42 AM
Crossover point for Scan-Speak Drivers - Opinions needed ShinOBIWAN Multi-Way 50 27th March 2005 01:25 PM
Page generated in 0.11592 seconds (80.79% PHP - 19.21% MySQL) with 11 queries
