Old 14th July 2010, 01:44 PM   #1
Default 18 inch sub placement cunundrum
Hello i have 2 18 inch subs. I am a DJ so i know how to set everything up and cable it all. My question is for home use ( when im not at an event) would the best placement of the subs be stacked and in a corner. more to the middle of the room. or in the doorway to an adjoining 100 square ft room. my main listening room is about 13 ftwide by about 30 feet long or approximately 400 sq feet, also for a room of this size what would be an appropriate approximate XO setting (upper and lower cutoffs).
thanks in advance
DJ Sprocket
Bigger the better... unless you like peace and quiet...
But we can fix that too.
Old 14th July 2010, 02:26 PM   #2
BobEllis's Avatar
Dig out the Harmon white paper on multiple subs. The goal of the paper is to make the sweet spot as big as possible. You'll want to experiment a bit, but a good starting point would probably be along the midpoints of opposite walls.
Crossover as low as your mains can handle at your target max SPL to make it less likely you will be able to localize the subs.
Old 14th July 2010, 02:29 PM   #3
its not going to be multiple subs as in in 2 different places rather stacked so as to essentially become one sub. each area that the subs could be would all be in a stacked configuration.
Old 14th July 2010, 02:44 PM   #4
BobEllis's Avatar
There are several room mode calculators such as the FRD tools one that will allow you to see what modes you will excite with various placements and choose the one that suits you.
A stack of 18" subs anywhere other than the corner will be visually imposing, and have ultra-low SAF. With separate placement you can probably get smoother overall response.
Old 14th July 2010, 02:46 PM   #5
i dont care about visual impositions as this system is only at home for a few days at a time then its disconnected and taken to a gig then back home again. as far as what SAF is if you could explain it please.
Old 14th July 2010, 02:47 PM   #6
BobEllis's Avatar
Spouse Acceptance Factor (an issue for some)
Old 14th July 2010, 02:54 PM   #7
no Issues with SAF of WAF more like DAF (Dad acceptance factor) but as its my part of the house and also my equipment which is here again gone again quite a bit i dont have to worry about that either
Hartley 18 Inch Subwoofer For Sale thetubeguy1954 Swap Meet 10 22nd April 2009 12:47 PM
18 inch Pro Driver Ricky Multi-Way 0 21st July 2007 03:11 PM
Wanted 18 inch Drivers- In India sonu Multi-Way 0 9th January 2005 12:35 PM
North Leviathan 18-inch SW driver Val Multi-Way 4 26th August 2002 05:42 AM
Page generated in 0.08039 seconds (76.66% PHP - 23.34% MySQL) with 10 queries
