Design help for Ascendent Avalanche 15
Old 14th October 2011, 03:23 PM   #31
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Originally Posted by bigjppop View Post
P.S. this is the amp I'm using:
The Apex Junior Subwoofer Amp
Have you tried hooking the driver up to another amplifier to see if it makes noise?
Old 14th October 2011, 05:49 PM   #32
GM is offline GM  United States
GM's Avatar
Assuming there's power to the amp, did you verify its on/off sw. is OK?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th October 2011, 08:58 AM   #33
bigjppop is offline bigjppop  United States
Well this has been a good learning experience. First up the box, I built it without bracing and I believe that was a mistake. The may that I built it makes it almost impossible to add bracing after the fact.
Second mistake, the amp. I liked the idea of having the frequency/volume controls on the front of the sub with the plate amp on the back. Now that I'm there, the connection between the two inside the box makes it very difficult to remove either of them to troubleshoot. Overall, I'm not really pleased with a plate amp period. Next time, going with a pro amp. Box construction, connectivity, future upgrades/repair issues would have been much easier with an outboard amp. Commercial sub, I definitely see the value in plate amps; DIY, pro amps for me.
So after several hours taking apart my sub and trying to figure out my amp problem, with no luck, I think I'm starting over again. I got the amp used, pretty cheap, so I can't really complain; I've bought/sold a lot of gear over the years and this was my first/only lemon. I'll keep and either try and get it working or use it for parts. It's really not very serviceable as lots of the important bits and pieces are well sealed up behind the circuit boards.
So, starting over. I'm still thinking sealed, 4^3 ft, but well braced this time. I'm probably going to use one of the Behringer iNuke amps with built in DSP. My plate amp claimed 350 watts into 4 ohms and I had WAY more output than I could use (my room is small) so I don't think I need gobs of power. I'm looking for clean deep extension, not max SPL. Should this one not go my way, maybe a sonotube next time around.
That's what DIY is all about, right?
Old 15th October 2011, 09:01 AM   #34
Thinking maybe this one or it's bigger brother
http://www.amazon.com/Behringer-iNUK...8669214&sr=8-6
Old 16th October 2011, 04:47 PM   #35
Quackhead is offline Quackhead  United States
IMO, good choice on a budget. I never did like the idea of mixing electronics with vibrations, ie "don't mount your amp on your sub box" comes to mind from my experiences in autosound. I don't care how much bracing you use, if it can get low n loud, it will vibrate. I have a pair of 15"subs in a 6.5 cu/ft @ 39hz box left over from our last system. I just put it in the corner of my living room and hit it with a Mackie 1400i......My God! it SLAMS. I had chosen the Powerbass 2XL 154D due to a 93 db spl rating and they sound 10 times better in my living room than they did in our Suburban.
Design help for Ascendent Avalanche 15Hide this!Advertise here!
Ascendant Audio Avalanche 15" D2 brewer_brewer Swap Meet 0 28th January 2010 04:08 AM
15 inch Cabinet Design?? Chicho Subwoofers 98 25th January 2008 07:47 PM
Plans for BIG 2x Ascendant Avalanche 15 subwoofer/TV stand BHTX Subwoofers 5 30th October 2006 12:42 PM
FS: Avalanche 12's WTB: Avalanche 18 noah katz Swap Meet 0 10th January 2006 03:40 AM
WTB: Two Avalanche 15 drivers Vadim Swap Meet 0 17th December 2005 08:47 PM
Copyright ©1999-2017 diyAudio
