Old 6th July 2010, 01:21 PM   #1
Courtec is offline Courtec  Netherlands
Question Adjusting zero position Subwoofer
Dear members,
I have a problem with two ElectroVoice DL18MT subwoofers. The zero position of the cone is to far to the back. The spinner seems a little dry. Does anybody know how to soften or regenerate the spinner and / or the outher ring of the speaker? The spinner seems to be impregnated with a kind of epoxy material. Perhaps a solvent can work.
thanks in advance
Old 6th July 2010, 02:25 PM   #2
chris661's Avatar
I got a pair of speakers where the cone was mis-aligned.
I pushed the cone forward by adding stuff between the basket and the cone. I left it for a couple of nights and it was close enough.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 6th July 2010, 03:50 PM   #3
djk is offline djk
djk's Avatar
Acetone will soften the phenolic resin in the spider. Don't overdo it and get it on the glue joints.
If you have an MTL4 it is a good idea to rotate the top and bottom woofers every year or so. Rotate the left and right woofers 180°.
Candidates for the Darwin Award should not read this author.
25-position switched attenuator using a pair of 5-position switches? ray_moth Tubes / Valves 1 4th May 2008 08:02 AM
Adjusting BIAS barmesan Tubes / Valves 2 10th January 2007 12:18 PM
adjusting gain? ThSpeakerDude88 Tubes / Valves 12 21st May 2006 11:20 PM
Adjusting the M250 @fundum Solid State 2 8th July 2004 08:02 AM
Page generated in 0.06992 seconds (72.62% PHP - 27.38% MySQL) with 10 queries
