Magnet mounting dipole drivers w/high moving mass
Old 10th July 2010, 12:50 AM   #11
twest820 is offline twest820
Originally Posted by matevana View Post
The driver would be clamped by its magnet using a sorbothane insulator.
Durometer and thickness? I'm curious what resonance frequency you chose as a cutoff.
Old 10th July 2010, 01:32 AM   #12
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Moved to woofers.
planet10 needs your help:
Let's help Ruth and Dave
Old 10th July 2010, 01:44 PM   #13
matevana is offline matevana
matevana's Avatar
The drivers have an Fs of 33Hz and are crossed using F-mods at 200Hz, 12dB/octave. They have a thick, coated paper cone designed for the elements, which results in a fairly high MMS of about 155 grams. Using a length of heater hose placed to my ear, I placed the other end at various points and am pretty confident the resonances are coming from the baffle as opposed to the driver itself.
The baffle is made of three layers, the outer being 1.2" hardwood, the center 1/4" compressed foamboard, and the inner is another layer of 1.2" hardwood. While the wood is fairly dense and fine grained, the overall baffle dimensions are small so the resulting weight isn't all that much, maybe only 20-25 lbs.
My thought was to physically decouple the driver from the baffle, with the exception of a rubber insulation channel used to reduce leakage at the "seal". The driver would be clamped at its greatest mass, it's magnet, and attached with rubber mounts to a hefty base, independent from the baffle.
Ed
Magnet mounting dipole drivers w/high moving massHide this!Advertise here!
15 inch woofers: which have low moving mass? elac310 Multi-Way 107 25th April 2012 12:11 AM
Bottlehead Seduction Moving Magnet Phono Preamp with many upgrades - Free Shipping dtm1962 Swap Meet 2 29th March 2010 05:24 PM
What currently available moving magnet cartridge is the best.??????.... oldheathkitphil Analogue Source 28 12th April 2008 02:16 PM
Moving Magnet Phono Load 6f6 Analogue Source 6 16th February 2007 10:25 PM
any moving magnet drivers? jcx Multi-Way 0 8th December 2004 03:23 AM
Copyright ©1999-2017 diyAudio
