Old 5th July 2010, 11:37 AM   #1
Village Plank's Avatar
Default Solid walnut subwoofers project
Ok the quality of veneers here is now so bad and getting so feindishly expensive I've decided to go down the solid wood route. Before anyone says "don't, It will split" I suggest they do a little research. I'm building a pair of 12s using PD12SB30's
The solid walnut in question is this... Walnut Worktops
Designed for use as kitchen work tops. This stuff is 40mm thick! and I dbout will need any bracing whatsoever. We have thick 27mm solid beech bedside dressers that are over 20 years old and have never split, warped nor moved.
There are so much more possibilities and benefits with solid wood than veneers.
1. Vastly reduced labour time
2. much eisier to machine and work with
3. constructed properly, MUCH stronger and likely to last a lifetime.
4. can be easily repaired if scrached or dented.
5. Solid wood gives a real presence of quality and beauty.
6. Most if not all quality solid wood peices only increase in value with time, Veneered MDF is all but worthless the moment it leaves your workshop.
The walnut is raw and unfinished, I will be sanding it down to 1800 grit and applying a liquid beeswax finish as a moisture barrier and to create a near mirror like finish.
Some will say I'm brave, stupid but hey.... who cares!
Old 5th July 2010, 12:15 PM   #2
Did it Himself
richie00boy's Avatar
Look forward to how you get on. Just remember that your dressing table isn't totally glued together and requires to be airtight
Thanks for the link, those prices are fantastic!
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 5th July 2010, 12:32 PM   #3
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
It sounds cool and I really hope it works out, should be beautiful
Those drivers look to be excellent quality, they should give good transient response with thier comparatively light cones and huge magnet system. How do you plan to implement them? Sealed/vented/LT sealed, or something else? These are designed for PA use and don't play very low in typical alignments, since they have high power handling LT sealed makes good sense
Old 5th July 2010, 12:46 PM   #4
I'm going vented, did an MDF test first and they sound great. Vented, 20" x 20" x 17" (17 x 17 x 17 internal dimensions) external dimensions with a 22" x 19" x 3" solid walnut base!
MDF test boxes!
Old 5th July 2010, 01:33 PM   #5
oublie is offline oublie  United Kingdom
Getting rid of vibration is darned difficult.
I've just built a test baffle from an old piece of Solid mahoghany 45mm thick 5 foot long 2 foot wide i have mounted one of the 4 skytronic 15 inch subs that I will be using open baffle (2 each side QTS 0.92 fs 30hz xmax 6mm ) and the thing rattles like mad with freq's below 50hz and this is with 20watts. Not thread stealing but it seems to me that clever bracing is the way to go.
Old 5th July 2010, 01:53 PM   #6
That thickness of mahogany should'nt rattle if you drive a bus into it!
Chances are its the god awful skytronics making the sound... Skytronic quality....... you may as well bash a kitten against the side of a van!
Old 5th July 2010, 02:27 PM   #7
Tried it with a dayton dvc as well 15" same thing happened its definately the wood moving
Old 5th July 2010, 02:53 PM   #8
mabe theres a hidden crack in the wood or you've substantionally weakend the baffle cutting four holes in it for x4 15s. Woods increase upto 7 times in strength when formed into a box. Even my test 18mm MDF boxes didnt buzz or rattle and I didn't brace them!
Old 6th July 2010, 01:20 PM   #9
Dr.EM's Avatar
These drivers do roll off quite early in a vented alignment (-10dB @ 48Hz simmed), but also roll off a bit slower than most, so factoring in room gain it should be possible to get decent extension. You'll certainly get good 'slam' with these around 60Hz
Do you notice any port noise with the test boxes? It seems quite a small port for a driver this size.
Old 6th July 2010, 01:47 PM   #10
Nope, perfect.... sorry I forgot to say, the PD12SB30's are custom, had them made with 4.5" coils and xmax is 17mm one way they are almost perfectly flat to 29Hz
Walnut chassis from Hammond Steve Eddy Parts 4 8th July 2010 04:58 PM
Turntable Recommendation for Solid Plinth Project hifileslie Analogue Source 6 12th March 2007 02:00 PM
Walnut for other wood Phergus_25 Swap Meet 0 27th February 2007 03:03 AM
Restaining Walnut Veneer Speaker cabs matski Multi-Way 1 1st October 2006 09:05 AM
my first solid project, discrete WJ/diamond buffer digi01 Solid State 22 22nd April 2005 07:48 AM
Page generated in 0.11124 seconds (82.41% PHP - 17.59% MySQL) with 11 queries
