#151 |
What, for an example, would be a good blend with the EL70's?
#153 |
I remember a rule of thumb for vented box, - max 2xVas = 2x27,24 = 54,48 liter. Or 2x1662 cubic inches = 3325 cubic inches = 1,924 cubic foot.
The metric system is so much easier. ![]() Itīs possible to build towers with vent on top, just behind the EL70, but i have no idea of how it would behave in practice. And donīt forget CG centre of gravity.
#154 |
Uhhm...
I've been re-thinking a little. Maybe it's possible to have three modules. The RSW-1060's for the deeper bass (but going higher at the beginning) and then something else that takes the mid-bass? You said that RSW-1060 wouldn't blend good and have much SQ but maybe it would be good for like 20(or 25) to 40/50hz or something and then something else takes like 40/50 to like 200 or something? But the mid-bass will have to be later in that case, lack of cash you know... Would that be possible? |
#155 |
EL70 has an xmax of 4,5mm (9mm p-p). I think there should be no problems.
If you donīt get happy with 1060, CSS SDX-10 XBL works fine in the same vented box round 45 liter. http://www.creativesound.ca/pdf/CSS-...ata-140408.pdf Last edited by Ragnwald; 2nd September 2010 at 01:17 PM. |
#156 | |
#157 |
Exactly, you just have to correct dimensions of venttubes.
Hehe.. now you got something to long for. ![]()
#158 |
#159 | |
Depends on what you learned in elementary school. I was in my 40s before I had to start including metric in my engineering drawings and for whatever reason I still can't make the mental conversion to catch such a gross typing error that I would never make using the Imperial system. What surprises/depresses me is that even though there was a Federal edict for the USA to convert to metric decades ago, it's for the most part still not taught to our youngsters in public schools except in a high school Chemistry course, but once out in the world they have little/no use for it in everyday life. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#160 |
frugal-phile(tm)
Yes. SDX10 is a REALLY nice driver. I have 4 here now for a pair of push-push woofers.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| which subs?___which enclosure.. help! | marty cataulin | Subwoofers | 0 | 4th April 2007 01:36 AM |
| Convert floor standers to subs with Tang Band 8" subs? | prerunnerv6 | Subwoofers | 3 | 26th February 2006 12:44 AM |
| 2 subs one box/2 subs 2 boxes | vetkilr | Subwoofers | 5 | 22nd February 2006 09:27 PM |
| Boston Acoustics RS8 subs need enclosure, help anyone? | rchua77 | Subwoofers | 8 | 15th January 2004 07:22 PM |
